Hello,
This is my first post with this forum (Thanks), also the first time with Leica SLR camera, just got R8 last week and summicron 50/2 version 1 (2 cams), without knowledge about Leica, so I mounted the lens with R8, I found it needs to stopped down by pressing down DOF lever to adjust aperture, the first film roll has not been finished yet (just 14 shots taken).
Today, I heard from someone that this lens version could possible damage camera contacts!!!, after did a research, there is a charting that support!!. I would like to ask as under what action should I do
- Unmount it out now and find 3 cams version to play with R8 later
- Finished the first roll first and then unmount it out
How do I know my R8 is still working and functioning?, no damage yet!!
Thanks in advance for an answer to help me
Sombat.
Hi Sombat!
I wouldn't worry. Leica just wont to be on the safe side. in theory - if the 1 cam is still aligned properly, which should normally be the case - , the cam shouldn't touch the ROM contacts at all. So, if your ROM Contacts do look alright, everything should be fine with your camera.
I bought my R9 with some lenses together. One lens was a 2 Cam 60mm Macro...…
Regards,
Torsten
22 hours ago, wagner said:
Hi Sombat!
Regards,
Torsten
Thank sir.
17 hours ago, james.liam said:
Perhaps OK but since repair for the R9 is  becoming impossible to come by, why gamble? Get a better 3-cam and sleep soundly.
Thank James. I will look for 3-cam
