I have a Digilux 2 SLR and I believe I have a software problem with it as it was starting to have problems where it would not turn off properly and then would not start again just leaving the Leica logo on the back screen. I had to remove the battery and reinstall it to get it going again. I don’t think it is a battery issue as it will not power up even on charge or when card is in or out. Is this a software problem?
x
On 6/20/2019 at 8:17 AM, jaapv said:
Unfortunately, whatever it is, you won't be able to get it going again. The camera is no longer supported.
Thanks I will just leave the battery out in between uses so it dies not get used up because it does not shut down properly.
Is it possible to reinstall the OS?
