caigy Posted June 12, 2019 Share #1  Posted June 12, 2019 Advertisement (gone after registration) Am I the only one who thinks the CL needs a silicone rubber eyecup? I find a lot of stray light comes at me from the side, depending of course on lighting conditions, where the sun is, etc. I find myself cupping my hand up against my face and around my eye to block stray light. Is there a generic eyecup available, or something that could be adapted to fit on the CL? 1 Link to post Share on other sites More sharing options...
Advertisement Posted June 12, 2019 Posted June 12, 2019 Hi caigy, Take a look here Eyecup for CL?. I'm sure you'll find what you were looking for!
Dave in Wales Posted June 13, 2019 Share #2  Posted June 13, 2019 (edited) 8 hours ago, caigy said: Am I the only one who thinks the CL needs a silicone rubber eyecup? I find a lot of stray light comes at me from the side, depending of course on lighting conditions, where the sun is, etc. I find myself cupping my hand up against my face and around my eye to block stray light. Is there a generic eyecup available, or something that could be adapted to fit on the CL? If one wears glasses, as do I, then you're rather stuck ! Edited June 13, 2019 by Dave in Wales Link to post Share on other sites More sharing options...
wda Posted June 13, 2019 Share #3 Â Posted June 13, 2019 I find it no hardship using my left hand, when needed, to shield against glare when shooting outside on a sunny day. Link to post Share on other sites More sharing options...
Petercoll Posted June 13, 2019 Share #4 Â Posted June 13, 2019 An eye cup would be a sensible accessory . I cannot see a thing , when I cannot shield with my left hand , and focus my long focus R telephoto at the same moment . 1 Link to post Share on other sites More sharing options...
ramarren Posted June 13, 2019 Share #5 Â Posted June 13, 2019 A wide brimmed hat works wonders for sunny days. Â 1 1 1 Link to post Share on other sites More sharing options...
jaapv Posted June 14, 2019 Share #6 Â Posted June 14, 2019 This eyecup is probably slightly loose. It must be possible to modify it by a rubber ring: Â http://www.fieldopticsresearch.com/shop/EyeShield-Winged-Eye-Cups/p/EyeShield-Compact-Size-sku-B002.htm Link to post Share on other sites More sharing options...
caigy Posted June 16, 2019 Author Share #7  Posted June 16, 2019 Advertisement (gone after registration) On 6/14/2019 at 7:41 PM, jaapv said: This eyecup is probably slightly loose. It must be possible to modify it by a rubber ring:  http://www.fieldopticsresearch.com/shop/EyeShield-Winged-Eye-Cups/p/EyeShield-Compact-Size-sku-B002.htm Well that's an interesting possibility. I'll look into that one. First thing to do is I have to measure the diameter of the CL's eyepiece to see if that one will fit. Link to post Share on other sites More sharing options...
ruskkyle Posted February 15, 2020 Share #8  Posted February 15, 2020 On 6/16/2019 at 10:25 PM, caigy said: Well that's an interesting possibility. I'll look into that one. First thing to do is I have to measure the diameter of the CL's eyepiece to see if that one will fit. Hi @caigy, same problem here. Did you come up with a solution? Link to post Share on other sites More sharing options...
caigy Posted February 16, 2020 Author Share #9  Posted February 16, 2020 On 2/15/2020 at 6:22 AM, ruskkyle said: Hi @caigy, same problem here. Did you come up with a solution? No, unfortunately I didn't.  I bought the eyecups (they are actually for binoculars), but couldn't figure out a way to make them fit tightly, so I ended up returning them. I'm still looking for a solution. Maybe if Leica comes out with a CL2 someday (with IBIS, I hope!), they will add the option of a fitted eyecup. Link to post Share on other sites More sharing options...
pebbles Posted April 5, 2020 Share #10 Â Posted April 5, 2020 It is very difficult shooting contre jour with the CL. An eyecup as for the R series would be a great help. Link to post Share on other sites More sharing options...
Gregm61 Posted April 6, 2020 Share #11  Posted April 6, 2020 On bright sunny days I do not go out with any mirrorless body without a hat. There’s nothing I experience as a glasses wearer with the CL that isn’t the exact same issue with any of the Olympus OMD mirrorless cameras with electronic finders. The biggest, best eyecup wouldn’t help at all for someone as blind and dependent on their glasses as me. 1 Link to post Share on other sites More sharing options...
pebbles Posted April 7, 2020 Share #12 Â Posted April 7, 2020 On 6/13/2019 at 10:07 AM, wda said: I find it no hardship using my left hand, when needed, to shield against glare when shooting outside on a sunny day. I am surprised no independent maker hasn't produced one. tt doesn't need to be stiff so a soft flexible rubber one would suit. 1 1 Link to post Share on other sites More sharing options...
pebbles Posted April 14, 2020 Share #13 Â Posted April 14, 2020 (edited) What is up with eBay advertisers. I have asked two sellers of rubber eyecups for the internal dimension of the cup. Nil repsonse. Edited April 14, 2020 by pebbles Link to post Share on other sites More sharing options...
pebbles Posted April 16, 2020 Share #14 Â Posted April 16, 2020 I have now asked another eBay seller of rubber eyecups the internal dameter of the end of the eyecup that fits over the camera eye piece. Still no response. I am wondering if the term "internal daimeter" is too much to comprehend.. Link to post Share on other sites More sharing options...
pebbles Posted June 2, 2020 Share #15 Â Posted June 2, 2020 The diameter of the CL eye piece is 25mm so a rubber slip on would need to be just under that to stay in place. I hve found one of 25mm internal diameter but it is too loose. Link to post Share on other sites More sharing options...
Lavaboy Posted June 12, 2020 Share #16  Posted June 12, 2020 (edited) Minolta X-700/370 eyecup. I'm sttill trying to find a way to keeping it on. Nothing will stick to the tapered silicone eyepiece. It goes on snug but because of the taper it can slip off easily if nudged. I hope someone can come up with a solution. We're almost there!  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited June 12, 2020 by Lavaboy Add text. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/298249-eyecup-for-cl/?do=findComment&comment=3991919'>More sharing options...
iidur Posted September 18, 2021 Share #17  Posted September 18, 2021 On 6/12/2020 at 2:47 AM, Lavaboy said: Minolta X-700/370 eyecup. I'm sttill trying to find a way to keeping it on. Nothing will stick to the tapered silicone eyepiece. It goes on snug but because of the taper it can slip off easily if nudged. I hope someone can come up with a solution. We're almost there!  Do you have any other pictures showing how this looks on the CL? And where did you get it? I searched for it and every single one I saw looked slightly different from yours. Link to post Share on other sites More sharing options...
