Hi All-
I am having an issue with my M6 TTL. Everything functions well but when I got to 1/1000 shutter speed, the meter suddenly turns off, as if I am going to the off selection on the shutter speed dial. Any advise?
Here is a video through the finder of the issue with narration -
Any insight is much appreciated.
Does 'Off' work correctly going in the other direction on the dial? So when on 'Off' is it off? In other words has some thingy-ma-bob inside slipped around and what was 'Off' is now 'B' and 'Off' is now 1/000th?
Edited by 250swb
  • 1 month later...
Did you find out what the problem was? I have the exact same issue with my TTL. Also some of the other speeds are now starting to become wonky (I.e. sometimes they work sometimes they don’t). It almost seems as though some mechanism in my dial is not making contact correctly.
I’ve so far tried the following with no success:
- fresh Silver Oxide batteries (SR44)
-fresh lithium battery (CR1/3N)
-cleaned contacts on backdoor with alcohol and eraser
- cleaned contacts in the battery compartment
From what I can tell when the meter does work it still meters accurately. Really strange and annoying
Edited by Fcmbr
  • 2 weeks later...
I finally sent it in but this is what I was told
"the Leica M6-TTL camera has a weak main shutter/meter contact unit that when its bad it usually causes more problems than what you're getting, my guess is that its on its way out & needs replacing. "
Still waiting for the official word. Will keep ya'll posted.
Edited by benjicam
  • 4 weeks later...
  • 2 years later...
My m6 classics light meter conked out on me and I kind of similar way. It started randomly turning off, then would only work when I’m focused to infinity on my lens.. then it stopped doing that. I brought it to my local shop who eventually sent it out to a few people with no luck. After 6 months of waiting, I finally got a response from Leica Germany saying it’s not repairable because they no longer have the parts :( I’m assuming that if Leica Germany won’t help me fix it, no one can but if anyone here has an idea or info/contacts, I’d really love to get it working again.
I would try emailing and ringing round the known Leica repairers around the world (sadly, there aren't all that many☹️). One may still have the relevant parts. Failing that you could look out for an otherwise broken donor camera but the durability of these cameras makes that an unlikely option (and the surge in value of the M6 means that even the most zinc corroded, bent out of shape, example will likely make the exercise an expensive undertaking).
That’s surprising because the common perception is that that an M6 classic could be repaired with MP parts while a TTL could not be. I’d give DAG a call before you give up.
