uprok Posted April 6, 2019 Share #1 Posted April 6, 2019 Advertisement (gone after registration) hallo, welcher Filter ist für den Schutz der Linse an der DLux 7 der Beste. Die Schutzkappe sollte noch montierbar sein (vermutlich nicht bei Slimfilter) Leica empfiehlt ja B+W Filter. Fährt das Objektiv mit Filter normal in die Kamera? Danke für eine Antwort Link to post Share on other sites More sharing options...
Advertisement Posted April 6, 2019 Posted April 6, 2019 Hi uprok, Take a look here Leica D Lux 7. I'm sure you'll find what you were looking for!
chris0959 Posted April 28, 2019 Share #2 Posted April 28, 2019 (edited) I only use B & W filters on all cameras. I've done extensive AB testing and reproducing image degradation with 'consumer' [Hoya, Tamron, Canon, etc.] filters. B & W filters cause so little distortion that I'm happy to invest in them and use them whenever I feel they will help the image. I do not agree with the age-old adage to put a UV / Skylight filter as a protection against damage. The exception being in very wet or sandy conditions. I've never damaged a filter, but have seen a lot of images ruined by ghost images and flare caused by I use a B & W polarizer on my D-lux often, and had absolutely no issues. Edited April 28, 2019 by chris0959 there are a ton of typos not in my original post Link to post Share on other sites More sharing options...
chris0959 Posted April 28, 2019 Share #3 Posted April 28, 2019 I use only B&W filters on all cameras. I've done extensive A-B testing and found repeatable image degradation with 'consumer' [Hoya, Tamron, Canon, etc.] filters. B&W filters caused so little distortion that I'm happy to invest in them and use them whenever I feel they will help the image. I do not agree anymore with the age-old adage to put a UV/Skylight filter on all lenses as a protection against damage. The exception being in very wet or sandy conditions. I've never damaged a protective filter, but have seen plenty of images ruined by extra flare and inexpensive filters! I use a B&W polarizer on my D-Lux often, with no issues. [What is up with this posting system? There are deletions to my original post, and actually whole new sentences I've never typed. Weird.] Link to post Share on other sites More sharing options...
