patricklgv Posted April 5, 2019 Share #1 Posted April 5, 2019 Advertisement (gone after registration) I can't figure out why the off/on switch basically defaults to C shooting mode - it takes a subtle touch to notch the S position - crazy! Also the video button cannot be reconfigured to another use. Could new firmware remedy these issues? Otherwise, I'm very happy with the quality of the photos I am getting. I love(d) my Fuji X100T, but the low light shots I am getting from the Q are a step above. Link to post Share on other sites More sharing options...
Advertisement Posted April 5, 2019 Posted April 5, 2019 Hi patricklgv, Take a look here Q-P questions/observations . I'm sure you'll find what you were looking for!
Matsaly Posted April 5, 2019 Share #2 Posted April 5, 2019 As a new Q-P owner myself I understand your frustration with the on/off switch. It's needlessly hard to finesse into the S position. I was aware the video button could not be reconfirmed when I bought the camera. If you view my earlier thread asking about firmware updates for the discontinued Q/Q-P , the general consensus was that Leica would no longer issue firmware updates. These are some of the reasons I am considering bailing out of my Q-P (at a big loss) and getting into a Q2. In my case I just want to make sure I'm not jumping out of the frying pan into the fire! Link to post Share on other sites More sharing options...
marchyman Posted April 5, 2019 Share #3 Posted April 5, 2019 The Q on-off issue has been mentioned by many over the years. It's an interesting issue as some can't turn the camera on without hitting the C setting every time while others never hit the C setting unless they forgot the camera was already on and try to turn it on again. I'm a member of the latter group. I've never had the opportunity to swap cameras with someone in the former group to see if it is a difference in cameras or a difference in people. I think the most you can do with the video button is mostly disable it. Even then I think it still work if you accidentally switch to video mode. Link to post Share on other sites More sharing options...
