8 hours ago, acmineiro said:
Is there a way to make the frame lines brighter?
Here, M10 forum, I think that is for the M10 which don't have the frame illumination window (only a cell to measure and adapt the LED illuminated framelines).
If you don't "block the front cell" (difficult in normal use, or with Elmarit-M 2.8/135mm), in this case the frames brightness would be very dim.
Play with the menu : "auto" or 5 other settings for frame's brightness to suit your use.
Sorry, I don't use the feature, so I took it as other brightness settings.
Just searched for the frame lines brightness settings, not found.
So I must admit that only "auto frame lines brightness" allowed in M10.
