Scanner advice needed
jlancasterd
A friend of mine who is using a Mac G5 needs to buy a good-quality scanner for 35mm films - transparency, colour negative and monochrome negative - the machine must be good enough to provide illustrations for a small, high quality publishing business.
What would members recommend in a price range up to around £600 (US$1,000)?
I don't have this scanner but since my scanner just waves the white flag I am forced to get an replacement. :-(
I consider to get an Epson 4990, which sells for about £ 400 here in UK. The output should be fine for any photo agency and you can scan prints and film. I am fed up w/ the pity service by HP so this time I favor another brand.
Another vote for Nikon's Coolscan V.
I upgraded from a Coolscan IV to the V out of a desire for greater resolution. All things being equal, I have not yet seen as great an increase in the quality of the finished print as I had hoped. So, if you can find a clean IV don't pass it up.
Of course, higher resolution means more data per image so I'll soon need to add more disk to my PhotoShop-dedicated computer.
Both Nikon scanners have been reliable; their software is easy to use although there is other scanning software one could use to drive this scanner too.
I briefly considered the well-regarded Minolta scanner, but given my familirity with how the Coolscan worked, the upgrade to the "V" was a no-brainer for me.
One last note: 95% of my work is with 35mm color negative materials, usually Fuji Professional NPH or NPZ. Occasionally some Chromes, but the greater availibility of C-41 processing and faster speed requirements push me over to the Fuji media alraedy mentioned. I have done some B&W work with chromogenic films but I would need to do a whole lot more to begin to understand how this particular film/scanner combination might work.
-g
The Nikon is awesome but it can't do panoramic or large format, both of which are important.
Neither of these are mentioned in the original question, which specifically asked for a 35mm scanner.
Thanks for the advice everyone. It looks as though the majority vote is for the Nikon Coolscan V - especially as my friend already has a good flatbed scanner that he is quite happy to use for negative sizes from 6x6 upwards, and he is unlikely to handle any Hasselblad 35mm panoramic images.
If you're getting a flatbed get a Epson V700 or V750. They are the only flatbed scanners who can compete with real film scanners. They are very good with 35mm.
If you're getting a dedicated 35mm filmscanner go for Nikon Coolscan V or LS5000. An used Canon FS4000US is also an option.
If I may be allowed to add another question to this thread.
I have recently aquired a Nikon Coolscan LS-8000ED to use with a PowerMac G4.
So far the Nikon Scan 4 software has caused problems with the Mac (locking when image scan files go above 10meg).
Demo versions of Silverfast and VueScan have worked really well with the Nikon. Before I invest does anyone have any advice on the use of these or is there a better alternative?
Thanks in advance
Andrew
Vuescan gets a lot of votes here (including mine) and has the benefit of working with virtually any scanner you care to mention. If you buy the Pro version (about $70?), you get free upgrades forever.
VueScan Scanning Software
Silverfast is much more expensive and scanner specific, so if you buy a Nikon version now and then want to scan from an Epson later, you will have to buy a second copy.
Any decent scanning software needs to be given time. As John Mead has said in the past, scanning is a skill that needs to be learned - it doesn't just happen, I'm afraid.
