Could someone please confirm if your SL also has the following issues.
When I have the camera in auto mode or EVF extended the camera ignores the automatic power off settings. What’s worse is that the camera will shut itself off if I don’t press any buttons after 10 seconds. In the LCD mode it works like expected. If I turn off the power save mode the camera will stay on.
This is happened on firmware 3.3 and 3.4. I am using a novaflex L to M adapter.
Is this a firmware bug or is my camera damaged?
Edited by sebben
Activation of the sleeping (or temporary power-off) mode should be independent of whether you are in the EVF, combined EVF+LCD, or LCD mode. I hardly turn the body off when I shoot; half-pressing of the shutter button quickly awakes the camera for new shooting. So something is odd with your body.
38 minutes ago, sebben said:
Does yours turn off all the screens within 10 seconds if you have the power save mode active? It wakes very quickly when I depress the shutter.
My default Power Saving settings are
    Power Saving Mode = Off
    Auto Power Off = 2 min
    All Displays Auto Off = 1 min
Actually, I do not use the "Power Saving Mode = On" - so my response was likely not responding to your question. Sorry for that...
However, when I set "Power Saving Mode = On", the body shuts down after 10 sec when the EVF only is activated. If the EVF+LCD or LCD is activated, the shut down follows the "Auto Power Off" instruction. So it looks like the body I have responds similarly to your body with "Power Saving Mode = On".
Edited by helged
