FeralCoton Posted February 3, 2019 Share #1 Â Posted February 3, 2019 Advertisement (gone after registration) I'm using a 50mm 1.4 summilux with my CL via the M-T adapter. Â When i power on the CL the screen displays unknown lens then recognizes the CL. Â and i have to tap select to choose it. Â This didn't used to happen. Â suggestions? Link to post Share on other sites More sharing options...
Advertisement Posted February 3, 2019 Posted February 3, 2019 Hi FeralCoton, Take a look here CL with M lens asks to select lens every power on. I'm sure you'll find what you were looking for!
M.piras Posted February 3, 2019 Share #2 Â Posted February 3, 2019 Have you tried to make a reset? You should make a try without saving any setup, at the moment you should start from factory default. Link to post Share on other sites More sharing options...
jaapv Posted February 3, 2019 Share #3 Â Posted February 3, 2019 Dirty window of the 6-bit coding reader? Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted February 5, 2019 Share #4  Posted February 5, 2019 What age Summilux is it? My 1970 vintage Summilux 35 f1.4 doesn't trigger the lens setting. I try to set the lens type, but I also ignore the message if I have gloves on or if I am moving around. If you are in a situation where you can't get to the menu, a light touch on the shutter release clears the message. Granted it is annoying. Tom Link to post Share on other sites More sharing options...
