jon m Posted January 23, 2019 Share #1 Posted January 23, 2019 Advertisement (gone after registration) Just got the Lim's half-case and very much like it. Have a problem in that the screw the case comes with doesn't allow for mounting to a tripod (in my case, for use with a strap that affixes to the tripod mount receiver). My last case ("very release") had on it a mounting screw with a female-threaded adapter inset into the screw, allowing the case to be screwed down and then screwed onto a tripod or strap. (That screw is too short to work with the Lim's case, which is deeper). Does anyone know where to get another screw of this sort, but longer, so I can get it working with the Lim's case? Link to post Share on other sites More sharing options...
Advertisement Posted January 23, 2019 Posted January 23, 2019 Hi jon m, Take a look here Question re: Lim's Half-case and tripod mount . I'm sure you'll find what you were looking for!
jon m Posted January 23, 2019 Author Share #2 Posted January 23, 2019 Ok, I found these: https://www.bhphotovideo.com/c/product/1410302-REG/megagear_mg1364_leather_camera_case_screws.html I just need now to figure out what sizes I need (camera side, strap side, and length). If anyone happens to have more insight (in case this is more obvious than I think) pls just let me know. Link to post Share on other sites More sharing options...
jon m Posted January 23, 2019 Author Share #3 Posted January 23, 2019 Ok, continuing to unravel this.... Q uses "Tripod thread A1⁄4 , DIN 4503 (1⁄4")" which I believe is simply a 1/4"-20 UNC thread. The strap uses this to attach: http://www.blackrapid.com/FastenR5-FR-5-Breathe. I'm not sure what they mean by Standard but I guess can assume 1/4"-20. Since it does fit, at least into the "adapter" screw I have with the old case; I'll need to try it direct into the camera but I assume that will also fit fine. Now the part I don't know is, what kind of screw I need to work with / fit the Lim's case. I emailed them so hopefully they'll have an answer. Link to post Share on other sites More sharing options...
Siriusone59 Posted January 23, 2019 Share #4 Posted January 23, 2019 I don't really follow exactly what you're attempting to accomplish but after checking my Lim's half case I noticed a 1/4"-20 standard tripod screw socket about half an inch away from the screw that holds the case to the camera. Did they perhaps forget to put one on yours? Link to post Share on other sites More sharing options...
jon m Posted January 23, 2019 Author Share #5 Posted January 23, 2019 Sorry, I realize my posts may not be 100% clear, I'm not entirely sure what words to use.... still learning terminology. The Lim's case did come with a screw and it goes onto the camera fine, but it's flat-head and so will not allow to mount to a tripod (or in my case, strap attachment) with case on. My other case has a case-screw that has female threads inside of it - similar to these: https://www.bhphotovideo.com/c/product/1410302-REG/megagear_mg1364_leather_camera_case_screws.html . That screw doesn't work with the Lim's case however (seems too short for the thicker Lim's case). So basically to sum it up, I need something like the screws in that link, but certain to fit the Lim's half-case and still accept the screw from the strap I linked above. Link to post Share on other sites More sharing options...
Siriusone59 Posted January 23, 2019 Share #6 Posted January 23, 2019 Will your strap attachment not fit into the female threaded tripod attachment point that is already present in the bottom of the case? Link to post Share on other sites More sharing options...
jon m Posted January 23, 2019 Author Share #7 Posted January 23, 2019 (edited) Advertisement (gone after registration) Nope, seems too short and/or the shape blocks the screw from making it far enough through the hole in the case to thread into the camera. A little hard to explain, but basically the screw that I was using before won't screw in, it doesn't get to the threads inside the camera through the Lims case. Edited January 23, 2019 by jon m Link to post Share on other sites More sharing options...
Siriusone59 Posted January 23, 2019 Share #8 Posted January 23, 2019 Does your case not have this hole in the bottom? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/293594-question-re-lims-half-case-and-tripod-mount/?do=findComment&comment=3670428'>More sharing options...
jon m Posted January 23, 2019 Author Share #9 Posted January 23, 2019 Hmmm, may well, I'll check when home. I assume that would be for the tripod / strap? Many thanks for helping me with this. Link to post Share on other sites More sharing options...
jon m Posted January 24, 2019 Author Share #10 Posted January 24, 2019 That was it, and yes I feel sorta dumb. Thanks for helping.... ‘case closed’. Link to post Share on other sites More sharing options...
Siriusone59 Posted January 24, 2019 Share #11 Posted January 24, 2019 You're welcome, glad I could help. Don't feel dumb, you were thinking of the other case and just overlooked this....that's what had me confused. 🤔 Link to post Share on other sites More sharing options...
