10 minutes ago, lysardman said:
Thanks for the information, however, the problem I have with the Nitecore is that it's a USB charger, I'd prefer a mains one.
I'm curious - why? I have a Nitecore one and it works well (for CL) - including from a USB mains adapter (Amazon Kindle, phone charger.......).
You're in a great location!  Few years since I was down that way - still need to go back, again.
https://www.nitecore.co.uk/Shop/Products/Chargers/13595-Nitecore-ULM9-Leica-Camera-Charger.html  -  cheaper than showing on that auction site.
Then plug it into a "decent" mains USB supply, not a cheap Chinese one.  Has the advantage you can use the Nitecore in a car with a 12V adaptor and the possibility of plugging into a computer...
  • 2 weeks later...
Well, I managed to get the Nitecore charger and get it working. However, when I put the own brand Leica battery into it to charge after a few minutes of charging it showed End so I took the battery out and put it into the M9 and had a look at the charge and it showed just over 75%. I repeated this with an OEM battery with the same results, except this showed below 75%.
So, I returned to the original Leica battery charger and put both the batteries in. They showed the flashing light for a few minutes then a constant green. Back in the M9 and this showed no change from above.
Any suggestions as to the cause of this and ideas what I do next?
Happy New Year to all
Hello, both the battery and the charger seem to be fine. (If there are no other indications of an incorrect operation.)
 >> From time to time, an (almost) complete discharge cycle is required in the camera to reset the battery status calculation. <<
Simply use the batteries periodically.
Here is some information about battery management:
Am 14.5.2015 um 09:46 schrieb Dao De Leitz:
A deeper understanding of the battery management gives the application note AN131.
Maxim Integrated, AN131: http://pdfserv.maximintegrated.com/en/an/AN131.pdf   ...
Quote AN131  Page 10:  ... ICA Reset to 0 after a complete discharge, ..., ... also adjust for cell differences and cell aging, becoming more accurate over time. ...
Thorsten
  • 3 years later...
I have the same issue now, what did you do to solve this problem please?
  • 3 weeks later...
