d.s. Posted September 26, 2018 Share #1 Â Posted September 26, 2018 Advertisement (gone after registration) Hello, Â Since I don't have any 135mm framelines currently visible in either of my M's, I'm wondering if they fall on the rule of thirds "lines" within the 35mm frame. Â Thanks in advance. Â - Daniel Link to post Share on other sites More sharing options...
Advertisement Posted September 26, 2018 Posted September 26, 2018 Hi d.s., Take a look here 135 Frame as Composition Guide. I'm sure you'll find what you were looking for!
a.noctilux Posted September 26, 2018 Share #2 Â Posted September 26, 2018 Welcome Daniel, Â Maybe... Â Maybe not depend on lens mounted. Â To judge by yourself in this example from M6 (TTL): Â Â Â In "real VF", some bottom lines are incomplete, cut out for LED display. Link to post Share on other sites More sharing options...
d.s. Posted September 27, 2018 Author Share #3  Posted September 27, 2018 Thanks, a.  I'd forgotten about that graphic. It looks like the 90 frames are closer, understandably, while the 135 corresponds to the approximate metering area: https://www.mir.com.my/rb/photography/companies/Leica/Leica-M3/Leica-MP/images/mag85x.gif  - Daniel 1 Link to post Share on other sites More sharing options...
sblitz Posted October 5, 2018 Share #4 Â Posted October 5, 2018 The 135 isn't much bigger than the focus patch, a good reason why you can do better with selective focus using an SLR and a long lens. Anyway, just aim and shoot and figure you are going to get the patch plus a bit more. Link to post Share on other sites More sharing options...
adan Posted October 5, 2018 Share #5 Â Posted October 5, 2018 The 135 framelines are three times the width and height of the RF patch. As you can see in the viewfinder guide above. Â However - keep in mind that the RF patch does not move for parallax correction, as do all the framelines. Focused at infinity, the RF patch will be a good "pointing guide" for the center of a 135 image, but focused at 1.5 meters, the RF patch will be significantly up and to the left within the composition you will get in the final picture. So compensate for that. 1 Link to post Share on other sites More sharing options...
d.s. Posted October 5, 2018 Author Share #6 Â Posted October 5, 2018 Good info, sblitz and adan. I recently decided to swap out my MP's 0.72-3 viewfinder with a 0.85-4, so I'll have a 135mm frame at my disposal soon again (my M6 0.85's 135 frame has been masked). I'm not sure if I'll wind up using it though. Link to post Share on other sites More sharing options...
