jmahto Posted September 16, 2018 Share #1  Posted September 16, 2018 (edited) Advertisement (gone after registration) Well, after experimenting and scanning with several rolls in past few months I had this thought.  Is pushing a film in chemical development *same* as either boosting exposure while scanning or increasing exposure in PP?Look at this example of Tri-X  Without any adjustment in scanning. On visual inspection also negative was on the lighter side (not sufficiently dense anywhere) and histogram on scanner confirmed that it was underexposed. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  After +1 exposure in LR. It seems to me that this exposure boost in PP has increased the contrast in the same way chemical push would have done. Why am I thinking about this? Because, if my observation is correct then I have the flexibility to push process frame by frame in PP after normal development.  And yes, that is E-Type on the road Edited September 16, 2018 by jmahto Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  After +1 exposure in LR. It seems to me that this exposure boost in PP has increased the contrast in the same way chemical push would have done. Why am I thinking about this? Because, if my observation is correct then I have the flexibility to push process frame by frame in PP after normal development.  And yes, that is E-Type on the road ' data-webShareUrl='https://www.l-camera-forum.com/topic/289519-pushing-a-film-in-dev-same-as-boosting-exposure-in-scanningpp/?do=findComment&comment=3594069'>More sharing options...
Advertisement Posted September 16, 2018 Posted September 16, 2018 Hi jmahto, Take a look here Pushing a film in dev *same* as boosting exposure in scanning/PP. I'm sure you'll find what you were looking for!
adan Posted September 18, 2018 Share #2  Posted September 18, 2018 Kinda-sorta.  "Pushing" is amplifying or multiplying or "cranking up the gain of" whatever base image is there. You start with a captured brightness range of between 0 and x, and if x is still too dark, you can multiply the whole range of brightnesses in the picture by, say, 4 (the "push"), and get a brightness range of between 0 to 4x (any number times zero is still zero, of course).  Result - a steeper line connecting 0 and the maximum (higher "gamma") = more contrast, plus a stronger maximum and mid-range - a picture you can see.  Thus all of the following do roughly similar things (assuming, in the case of a digital capture, that the sensor is "ISO-invariant"):  - underexpose a sensor by setting the camera to a higher ISO than base, and letting the camera "push" or multiply the image values for you - underexpose a sensor by leaving the camera ISO setting at base ISO, but using a hand-held metered exposure (or exposure-compensation dial) to feed it too little light, and then doing the amplification in LR or Photoshop or whatever. - underexpose film, and amplify the silver in it by extended development (pushing it chemically) - underexpose film, and give it normal development, and then scan the film, and use LR to "crank up the gain" just like any other digital image.  The main obvious difference will be this: chemical "pushing" tends to increase the "grain/noise" in the highlights, by creating more and more silver in the only place there is any exposure to develop. Digital pushing tends to increase the "grain/noise" in the shadows, because that is where the signal/noise ratio is worst. *  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Pushed film detail -                                                            Pushed (high ISO - 16000) digital - clean shadows, noisy bright tones                                   noisy shadows, smoother highlights  Digital pushing is rather like recording sound with a weak mic or preamp, and then trying to recover the original sound by cranking the primary amp or playback volume up to 11 - you can hear the song, but also every tiny pop and scratchy bit of static noise.  There may be other differences, just due to the fact that the whole "film" thing tends to be non-linear, especially at the extremes of exposure (toe and shoulder of the film's response to light = "characteristic curve" ** ), and in development (where to compensate for a whole stop of underexposure (half the needed light) you give 1.4x (root-2) the development. You may find that playing with a "curve" in LR better replicates chemical pushing than an overall exposure bump of "+1". Or some combination of curves, exposure, contrast, shadows or highlights, etc. _________________  * the one thing that frustrates me about digital - after 40 years of seeing pushed film pictures with (usually) grainy highlights and smooth empty shadows, the noisy shadows and "smoother" highlights of high-ISO digital just look - wrong - to me.  ** http://www.sprawls.org/ppmi2/FILMCON/#The%20Characteristic%20Curve  3 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Pushed film detail -                                                            Pushed (high ISO - 16000) digital - clean shadows, noisy bright tones                                   noisy shadows, smoother highlights  Digital pushing is rather like recording sound with a weak mic or preamp, and then trying to recover the original sound by cranking the primary amp or playback volume up to 11 - you can hear the song, but also every tiny pop and scratchy bit of static noise.  There may be other differences, just due to the fact that the whole "film" thing tends to be non-linear, especially at the extremes of exposure (toe and shoulder of the film's response to light = "characteristic curve" ** ), and in development (where to compensate for a whole stop of underexposure (half the needed light) you give 1.4x (root-2) the development. You may find that playing with a "curve" in LR better replicates chemical pushing than an overall exposure bump of "+1". Or some combination of curves, exposure, contrast, shadows or highlights, etc. _________________  * the one thing that frustrates me about digital - after 40 years of seeing pushed film pictures with (usually) grainy highlights and smooth empty shadows, the noisy shadows and "smoother" highlights of high-ISO digital just look - wrong - to me.  ** http://www.sprawls.org/ppmi2/FILMCON/#The%20Characteristic%20Curve  ' data-webShareUrl='https://www.l-camera-forum.com/topic/289519-pushing-a-film-in-dev-same-as-boosting-exposure-in-scanningpp/?do=findComment&comment=3595076'>More sharing options...
jmahto Posted September 18, 2018 Author Share #3  Posted September 18, 2018 Kinda-sorta.  "Pushing" is amplifying or multiplying or "cranking up the gain of" whatever base image is there. You start with a captured brightness range of between 0 and x, and if x is still too dark, you can multiply the whole range of brightnesses in the picture by, say, 4 (the "push"), and get a brightness range of between 0 to 4x (any number times zero is still zero, of course).  Result - a steeper line connecting 0 and the maximum (higher "gamma") = more contrast, plus a stronger maximum and mid-range - a picture you can see.  Thus all of the following do roughly similar things (assuming, in the case of a digital capture, that the sensor is "ISO-invariant"):  - underexpose a sensor by setting the camera to a higher ISO than base, and letting the camera "push" or multiply the image values for you - underexpose a sensor by leaving the camera ISO setting at base ISO, but using a hand-held metered exposure (or exposure-compensation dial) to feed it too little light, and then doing the amplification in LR or Photoshop or whatever. - underexpose film, and amplify the silver in it by extended development (pushing it chemically) - underexpose film, and give it normal development, and then scan the film, and use LR to "crank up the gain" just like any other digital image.  The main obvious difference will be this: chemical "pushing" tends to increase the "grain/noise" in the highlights, by creating more and more silver in the only place there is any exposure to develop. Digital pushing tends to increase the "grain/noise" in the shadows, because that is where the signal/noise ratio is worst. *  pushedfilm.jpg pushdigi.jpg Pushed film detail -                                                            Pushed (high ISO - 16000) digital - clean shadows, noisy bright tones                                   noisy shadows, smoother highlights  Digital pushing is rather like recording sound with a weak mic or preamp, and then trying to recover the original sound by cranking the primary amp or playback volume up to 11 - you can hear the song, but also every tiny pop and scratchy bit of static noise.  There may be other differences, just due to the fact that the whole "film" thing tends to be non-linear, especially at the extremes of exposure (toe and shoulder of the film's response to light = "characteristic curve" ** ), and in development (where to compensate for a whole stop of underexposure (half the needed light) you give 1.4x (root-2) the development. You may find that playing with a "curve" in LR better replicates chemical pushing than an overall exposure bump of "+1". Or some combination of curves, exposure, contrast, shadows or highlights, etc. _________________  * the one thing that frustrates me about digital - after 40 years of seeing pushed film pictures with (usually) grainy highlights and smooth empty shadows, the noisy shadows and "smoother" highlights of high-ISO digital just look - wrong - to me.  ** http://www.sprawls.org/ppmi2/FILMCON/#The%20Characteristic%20Curve  Thanks for detailed reply. I will have to think about your following comment that is very fascinating: ...The main obvious difference will be this: chemical "pushing" tends to increase the "grain/noise" in the highlights, by creating more and more silver in the only place there is any exposure to develop. Digital pushing tends to increase the "grain/noise" in the shadows, because that is where the signal/noise ratio is worst.... Quote Link to post Share on other sites More sharing options...
adan Posted September 19, 2018 Share #4 Â Posted September 19, 2018 BTW - how did you meter your Jag picture? Quote Link to post Share on other sites More sharing options...
jmahto Posted September 19, 2018 Author Share #5 Â Posted September 19, 2018 BTW - how did you meter your Jag picture? I did sunny16 (f/16 and 1/500), Tri-X 400 lab developed. I am just wondering whether 1/500 sec is not that accurate or I might have made a mistake and set speed higher (1/1000). Later is a possibility since in the same roll there is another sunny16 shot in similar sun that looks ok. I shot from running car and might not have set exposure correctly. Quote Link to post Share on other sites More sharing options...
pico Posted September 19, 2018 Share #6 Â Posted September 19, 2018 One stop would not make that big a difference. Something else is going on. Quote Link to post Share on other sites More sharing options...
jmahto Posted September 20, 2018 Author Share #7 Â Posted September 20, 2018 Advertisement (gone after registration) One stop would not make that big a difference. Something else is going on. Any guess? I have used Sunny16 many times after this and it has been fine (even in the same roll). My own guess is mistake in exposure setting (most probably) or inaccurate shutter (less probable). Quote Link to post Share on other sites More sharing options...
adan Posted September 20, 2018 Share #8  Posted September 20, 2018 (edited) 1) side-lighting: need to add ~1 stop for that (with side lighting, on average, half your subject is front-lit and half your subject is backlit, just like a half-moon)  2) tinted car windshield - need to add a "filter factor" for that. Anywhere between 2/3rds-stop for basic faintly green safety glass (blocks 35% of the visible light), to several stops with a serious dark tint (factory tinting blocks ~75-80% of the visible light).  https://oceanoptics.com/transmission-characteristics-sunglasses-tinted-windows/#foobox-5/0/Figure-5-UV-Vis-Transmission-in-Car-Window-Tinting.jpg  3) plus, of course, under sunny 16, Tri-X nominally needs 1/400th sec and f/16 - 1/500th is technically a tad under to begin with. I usually cheat to the half-stop between 11 and 16 ("f/13") with 400 film and 1/500th sec.  OTOH, if a film Leica shutter (except electronic M7) is off-spec, it is usually too slow, and gives back the needed half-stop. Typically, unless very recently serviced, a Leica M clockwork shutter at "1/1000th" is running about 1/750th.  But it all adds up. Edited September 20, 2018 by adan 1 Quote Link to post Share on other sites More sharing options...
AntonioF Posted September 20, 2018 Share #9  Posted September 20, 2018 (edited) When I push film (usually from 400 to 1600) I do it also for other 2 reasons, besides the extra flexibility of the higher iso: 1 - I want a certain look with more contrast (and of course I embrace the grain) 2 - the extra 2 stops gives me the possibility to use a smaller aperture and get more depth of field in worse light conditions  You might get the constrast in PP, but not the DOF.  Well, after a second thought, you could use anyway a small aperture, shoot underexposed, don't push and correct in PP (which is what you want to do) but you'll get a lot of extra digital noise/grain in the shadows if it's more than 1 stop. That's my experience, at least.  PS I usually cheat with Sunny 16 as well: iso 400 -> 1/500 F11 Edited September 20, 2018 by AntonioF 1 Quote Link to post Share on other sites More sharing options...
adan Posted September 20, 2018 Share #10  Posted September 20, 2018 Anyway - here is your first jpg, revised with a PhotoShop "Curves" adjustment. The blockiness in the shadows is from the jpg compression of your post; you shouldn't see that, working from your original scan file.  At this scale, of course, any noise or grain is mostly too small to see. And the exact curve drawn can vary according to taste - you don't have to like mine.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/289519-pushing-a-film-in-dev-same-as-boosting-exposure-in-scanningpp/?do=findComment&comment=3596445'>More sharing options...
jmahto Posted September 20, 2018 Author Share #11  Posted September 20, 2018 (edited) Anyway - here is your first jpg, revised with a PhotoShop "Curves" adjustment. The blockiness in the shadows is from the jpg compression of your post; you shouldn't see that, working from your original scan file.  At this scale, of course, any noise or grain is mostly too small to see. And the exact curve drawn can vary according to taste - you don't have to like mine.  revisedarkscan.jpg Thanks Andy, That looks much better than simply using exposure slider.  I tried to mimic the curve in LR and results came out similar. I had to add 0.5 exposure as well. See the settings. The grain (crop) doesn't look bad either. I guess now I have a tool to recover from underexposure.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Crop (licence plate masked) Edited September 20, 2018 by jmahto Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  Crop (licence plate masked) ' data-webShareUrl='https://www.l-camera-forum.com/topic/289519-pushing-a-film-in-dev-same-as-boosting-exposure-in-scanningpp/?do=findComment&comment=3596510'>More sharing options...
pico Posted September 20, 2018 Share #12 Â Posted September 20, 2018 Interesting. I have never seen a black E-Jag. 1 Quote Link to post Share on other sites More sharing options...
Jeff S Posted September 21, 2018 Share #13 Â Posted September 21, 2018 Interesting. I have never seen a black E-Jag. You could have had one for a half million... Â https://www.hemmings.com/blog/2013/11/22/series-i-jaguar-e-type-sets-auction-record-at-new-york-sale/ Â Or a lot cheaper; it was an available color for some variations. Â Jeff Quote Link to post Share on other sites More sharing options...
pico Posted September 21, 2018 Share #14 Â Posted September 21, 2018 You could have had one for a half million... Â https://www.hemmings.com/blog/2013/11/22/series-i-jaguar-e-type-sets-auction-record-at-new-york-sale/ Â Or a lot cheaper; it was an available color for some variations. Â The one in the OPs picture was a +2 model, no? Â Half million? Can we get snow tires for it? Quote Link to post Share on other sites More sharing options...
Jeff S Posted September 21, 2018 Share #15  Posted September 21, 2018 The one in the OPs picture was a +2 model, no?  Half million? Can we get snow tires for it? https://axleaddict.com/cars/Jaguar-E-Type-Original-Colors  Jeff 1 Quote Link to post Share on other sites More sharing options...
jmahto Posted September 21, 2018 Author Share #16  Posted September 21, 2018 https://axleaddict.com/cars/Jaguar-E-Type-Original-Colors  Jeff I didn’t know there were many shades of greens! Quote Link to post Share on other sites More sharing options...
jmahto Posted September 21, 2018 Author Share #17 Â Posted September 21, 2018 Interesting. I have never seen a black E-Jag. Lol. If I remember correctly, it was dark blue. Quote Link to post Share on other sites More sharing options...
adan Posted September 23, 2018 Share #18 Â Posted September 23, 2018 (edited) Thread drift - I thought one only saw "Jaggies" in digital photos. Â Jayant, you need a higher-megapixel film. Â https://en.wikipedia.org/wiki/Jaggies Edited September 23, 2018 by adan Quote Link to post Share on other sites More sharing options...
pico Posted September 23, 2018 Share #19  Posted September 23, 2018 (edited) https://axleaddict.com/cars/Jaguar-E-Type-Original-Colors  Jeff  Gosh, too many choices! I cannot make up my mind! One that most closely resembles a chrome M10? Edited September 23, 2018 by pico Quote Link to post Share on other sites More sharing options...
jmahto Posted September 26, 2018 Author Share #20 Â Posted September 26, 2018 Thread drift - I thought one only saw "Jaggies" in digital photos. Â Jayant, you need a higher-megapixel film. Â https://en.wikipedia.org/wiki/Jaggies Where did you see "jaggies" in my scan? I might be missing something. Â When you said high megapixel film, you mean TMax100 instead of Tri-X? Quote Link to post Share on other sites More sharing options...
