Hi I found another problem with my 240.
When I align the image and object in the viewfinder, the photo comes out to be out of focus.
if the image is on the left side of the object, if lucky, it is in focus. Any ideas?
The lens was used in M9 and has no issues at all. The 240 live view can still take sharp images.
Can anyone help me again? Thank you
If what is in focus using the rangefinder is different from what is in focus using live view then either the lens or the camera or both need to be adjusted by Leica. If the lens is ok on another camera then it is more likely to be the camera which needs attention.
I am sure  it is the camera's problem.  Is it a big problem? Is it easy to have it adjusted?
It really gets problematic when you have multiple bodies, LOL, as some of the lenses (primarily in the 75-135mm range and at wider apertures) focus more accurately on one than they will on another.
Think the 240 has some problem. I focus the same way  in the m9, and  image comes out to be clear. In 240, the image comes out to be blurry.
or If I use live view to do focusing, and check the viewfinder and the image and object do not align.
It might be simple enough to do it yourself. Search the forum for instructions. The treads usually say how to tell if you have the easy problem.
Do not know what the problem is called.
Like viewfinder horizontal or vertical alignment adjustment?
In that case send it in, send it to a reliable third-party repair shop that can handle Leicas. Im sure our Canadian forum members can recommend somebody.
I called KINDERMANN, they said they do not handle digital camera. Anyone has any suggestions around Toronto area.
  • 2 weeks later...
