jlancasterd Posted July 13, 2007 Share #1 Posted July 13, 2007 Advertisement (gone after registration) I've just ordered a 65mm Elmar and 16464 mount to go with a Visoflex 3 that I acquired a couple of months ago. I'm assuming that I will need to use an IR-cut filter with this lens to ensure true colour fidelity when it is mounted on my M8 (I'm hoping to use it for flower close-ups amongst other things). however, I see that, in true Leitz/Leica tradition, it has a non-standard 41mm filter thread - AFAIK this is shared only with the long-departed Summarit 50/1.5. Does anyone have a suggestion as to a work-around using another filter size - or is it a candidate for a Milich special? Ideally I'd like to be able to mount a lens hood in front of the filter. I knew I'd regret selling my M2 with its Summarit, UV filter and rectangular hood all those years ago... Link to post Share on other sites More sharing options...
Advertisement Posted July 13, 2007 Posted July 13, 2007 Hi jlancasterd, Take a look here IR-cut filter for 65mm Elmar. I'm sure you'll find what you were looking for!
Guest guy_mancuso Posted July 13, 2007 Share #2 Posted July 13, 2007 John maybe a step up ring to 43 or 49mm than get a screw in hood for it. Check B&h for a step up ring. Actually I will look too. 41mm could be tough though Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted July 13, 2007 Share #3 Posted July 13, 2007 Hot damn B+W 41mm to 49mm Step-Up Ring (Lens to Filter) #9h and than eBay: 49mm Wide Angle Metal Lens Hood Shade New Fits 49 mm (item 300128948466 end time Jul-16-07 13:54:14 PDT) Your in Link to post Share on other sites More sharing options...
jlancasterd Posted July 13, 2007 Author Share #4 Posted July 13, 2007 Hot damn B+W 41mm to 49mm Step-Up Ring (Lens to Filter) #9h and than eBay: 49mm Wide Angle Metal Lens Hood Shade New Fits 49 mm (item 300128948466 end time Jul-16-07 13:54:14 PDT) Your in Thanks Guy! This forum really is incredible - that was less than 10 minutes from my query to an answer!! Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted July 13, 2007 Share #5 Posted July 13, 2007 Glad i could help . On the hood though might not need the wide angle one and since there only 10 dollars or so you might squeeze by with a normal 49mm , it may cover better. i would get both and see what works the best Link to post Share on other sites More sharing options...
