Deliberate1 Posted September 3, 2018 Share #1 Posted September 3, 2018 Advertisement (gone after registration) Friends, I have never had a Leica charger go bad on me, but this may be the first. I hooked a depleated battery up to it, and within just a few minutes, both the yellow and green lights were blinking. I disconnected the battery. The was no charge. I hooked up a second battery to make sure it was not a battery failure. And both green and yellow lights were illuminated solid with just a couple minutes. Again, no charge. Dead charger? Is there any reset or is it time to take out the credit card? Are there third party alternatives? Thanks. David Link to post Share on other sites More sharing options...
Advertisement Posted September 3, 2018 Posted September 3, 2018 Hi Deliberate1, Take a look here Dead Charger? . I'm sure you'll find what you were looking for!
mgrayson3 Posted September 3, 2018 Share #2 Posted September 3, 2018 There is a way to reset the charger. I *think* you plug in the battery first, then plug the charger into the wall. Good luck! Link to post Share on other sites More sharing options...
Deliberate1 Posted September 3, 2018 Author Share #3 Posted September 3, 2018 There is a way to reset the charger. I *think* you plug in the battery first, then plug the charger into the wall. Good luck! Ah, would that it was so easy. Did not work. But appreciate the suggestion. Perhaps, fortuitously, my plan was to send the 006 down to Leica Miami next week for a sensor check for hot pixels and possible corrosion. I will send the charger as well. My certified camera was one that came with the three year warranty that runs for another couple months. Anyone know if the accessories, like a charger, are covered? David Link to post Share on other sites More sharing options...
John McMaster Posted September 3, 2018 Share #4 Posted September 3, 2018 I had a monochrom charger die, it was swapped out. Also my first Pro-S battery charger was DOA, again swapped out. I would look into the pro charger, I have grips on both my cameras (S2-P and 007) with 4 batteries for each, so charge in pairs.... john 1 Link to post Share on other sites More sharing options...
mgrayson3 Posted September 3, 2018 Share #5 Posted September 3, 2018 +1 on the pro charger. Link to post Share on other sites More sharing options...
alan.y Posted September 3, 2018 Share #6 Posted September 3, 2018 My experience w the S charger and batteries is that they are very temperamental. The blinking problem just happens once every so often. It sometimes fixes itself if you unplug and reply. Other times I have to discharge the battery and try again. This has been discusssed here before and the conclusion by the OP was something wrong with the charger. I tend to think like the S body they just like/have to malfunction every so often... 3 Link to post Share on other sites More sharing options...
Deliberate1 Posted September 3, 2018 Author Share #7 Posted September 3, 2018 Advertisement (gone after registration) My experience w the S charger and batteries is that they are very temperamental. Alan, this is my first issue with the charger in three years. I am far more fickle than that. David Link to post Share on other sites More sharing options...
djmay Posted September 4, 2018 Share #8 Posted September 4, 2018 I have had the blinking lights also. It always resolved itself by removing power. I have two chargers for backup while traveling. This goes for the M as well. Belts and braces Jesse 1 Link to post Share on other sites More sharing options...
helged Posted September 4, 2018 Share #9 Posted September 4, 2018 Yes, a charger backup solution is good to have. I have returned one M240-type and one SL-type of charger to Leica; one stopped to work, the other started to smell. So it appears for me that the cost of Leica charges are quite a bit higher than the quality. Or I could have been unlucky (being quite careful with the charging, I would add). No issue with the S-charger so far. 2 Link to post Share on other sites More sharing options...
jip Posted September 4, 2018 Share #10 Posted September 4, 2018 My charger was replaced by Leica... It would say batteries were charged but actually they would only hold 50% or less. 1 Link to post Share on other sites More sharing options...
leicapages Posted September 25, 2018 Share #11 Posted September 25, 2018 Charger made in China. Not matching the expensive camera, IMHO. Link to post Share on other sites More sharing options...
Deliberate1 Posted September 26, 2018 Author Share #12 Posted September 26, 2018 Charger made in China. Not matching the expensive camera, IMHO. OP here. Agreed. But I see a marginal charger as Leica marketing tool. Rather than spend $200 to replace it, I have since spent $8600 for a new one - and they threw in a new 007 for nothing. Link to post Share on other sites More sharing options...
leicapages Posted September 26, 2018 Share #13 Posted September 26, 2018 (edited) OP here. Agreed. But I see a marginal charger as Leica marketing tool. Rather than spend $200 to replace it, I have since spent $8600 for a new one - and they threw in a new 007 for nothing.Haha, glad that you take it with a sense of humor! I hope the issue is meanwhile solved for you. Does anyone know if the Pro Charger is also made in China? Given its high price, it shouldn’t. Edited September 26, 2018 by leicapages Link to post Share on other sites More sharing options...
John McMaster Posted September 26, 2018 Share #14 Posted September 26, 2018 Mine says it is Made in China, I do not have a problem with that.... john Link to post Share on other sites More sharing options...
leicapages Posted September 26, 2018 Share #15 Posted September 26, 2018 Mine says it is Made in China, I do not have a problem with that.... john ouch I would not have a problem with that if the price was matched accordingly... Link to post Share on other sites More sharing options...
albertknappmd Posted September 26, 2018 Share #16 Posted September 26, 2018 anything is possible. I always carry a second charger but since 2010, have never required it! Albert Link to post Share on other sites More sharing options...
Deliberate1 Posted September 26, 2018 Author Share #17 Posted September 26, 2018 ouch I would not have a problem with that if the price was matched accordingly... Agreed. But that would be un-Lieca like. Case in point, the made in China Q battery costs about $95. Identical alternatives (made in same facility?) without the Leica imprimatur cost one-third of that. Images I take with both look the same to me. Perhaps i am not looking close enough. David Link to post Share on other sites More sharing options...
leicapages Posted September 27, 2018 Share #18 Posted September 27, 2018 Agreed. But that would be un-Lieca like. Case in point, the made in China Q battery costs about $95. Identical alternatives (made in same facility?) without the Leica imprimatur cost one-third of that. Images I take with both look the same to me. Perhaps i am not looking close enough. David which alternative battery for the Q did you find? Link to post Share on other sites More sharing options...
Deliberate1 Posted September 27, 2018 Author Share #19 Posted September 27, 2018 which alternative battery for the Q did you find? https://www.adorama.com/sgbp51.html?gclid=EAIaIQobChMI2ZCzhaLb3QIVxJyzCh3Y3g2REAYYASABEgKvtvD_BwE This one is $40. I recall paying a bit less than that. Leica doppleganger is sold at "discount" at $95 +/-. David 1 Link to post Share on other sites More sharing options...
