35:1.4 v2 at F8 ish , Portra, MP
Portra 800, M6 TTL, Delhi Spice Market
35 Summilux v2 pre asph and M8
  • Like 15
35 Summilux v2 1969 on M10-P
35 Summilux v2 1969 @ f5.6 (on M10-P)
@ f1.4
This thread is making me want to pull the trigger on a late v2 German copy. I tested 1 German copy (not the same as the one I'm eyeing) side by side with a Canada one and I was surprised to see the central sharpness of the German one to be higher than the Canada one. I didn't test sharpness in the corners or stopped down.
I tried to find this info on the web but couldn't find it - does anyone know the weight of the lens with a hood and filter? Also, is focus shift an issue with this lens?
I plan to use it wide open but would stop it down readily as there's no size penalty disadvantage if I do so. I took a while to find a late-ish German copy (serial number 35xxx onwards, though I'm not sure when they became "sharp" due to tweaks in coatings or whatever they did so i figured just to look out for those at the end of production)..it was almost as if the titanium ones are easier to find...but not as easy on the wallet. I prefer a black lens but I do see the appeal of the titanium version. Whatever is cheaper is the one for me - either way I wish I picked one of these lenses up earlier!
Just a short answer not to highjack this thread,  I'd say get the lens you tested if it stands out as a well calibrated copy , matching your own camera.
From my experience having owned twice the titanium copy, it has a slightly more modern rendering probably due to the coatings .
My personal preference goes for  the early canadian ones .
You will find more infos in this thread:
Edited by JMF
35 Summilux steel rim on M10
Goggled M3 Steel Rim Summilux on M6J with Kodak Vision3 200T
  • Like 14
Cidade de Deus - City of God
Rio de Janeiro.  2013
35 Summilux pre asph v2 on M8
  • Like 13
Bandra, Mumbai India
35:1.4 v2 & Portra 800. MP
35 Summilux v2 on M8
  • Like 13
35 Summilux v2 1981 on Leica M-A with Acros 100
  • Like 13
Summilux-M 35mm F1.4 V2(11860), M10M
