I am sure this has been discussed before, but I can`t find it. I wanted to test out an old Russian Tair 4.5/300, which I mounted cmbining an M42 and Novoflex EOS adapter. The viewfinder is completely black. What changes to settings do I need to set for this to work?
Ivar, you need a dumb/mechanical M42-to-L mount adapter; it's the electronic Novoflex EOS adapter that is the root of the problem.
Ok - so with a simple (and almost free) Chinese EOS - M42 adapter in combination with a Novoflex EOS adapter, this will not work regardless?
How is the combo connected to the SL??
