Jeff S Posted August 7, 2018 Share #21 Posted August 7, 2018 Advertisement (gone after registration) Jaap excerpted from the M FAQ (frequently asked questions). I think you will benefit greatly from reading the entire section... https://www.l-camera-forum.com/topic/216580-leica-m8-m82-m9-m9p-mm-mtyp240-faqs-questions-with-answers/page-1 Jeff 2 Link to post Share on other sites More sharing options...
Advertisement Posted August 7, 2018 Posted August 7, 2018 Hi Jeff S, Take a look here M10; Bulb, Polarizer, Rendering !!!!... I'm sure you'll find what you were looking for!
jaapv Posted August 7, 2018 Share #22 Posted August 7, 2018 However, bear in mind that the FAQ are universal and that the M10 has advanced over the M8 They could do with some updating. 1 Link to post Share on other sites More sharing options...
tobey bilek Posted August 9, 2018 Share #23 Posted August 9, 2018 2. Leica and top brands are neutral grey so color balance is unchanged. Older Leitz, and cheap brands may be green tinted. Do white balance with grey card if you have problems. See instruction book. Leica rendering is among the very best. Do not worry. 1 Link to post Share on other sites More sharing options...
jaapv Posted August 9, 2018 Share #24 Posted August 9, 2018 Jaap excerpted from the M FAQ (frequently asked questions). I think you will benefit greatly from reading the entire section... https://www.l-camera-forum.com/topic/216580-leica-m8-m82-m9-m9p-mm-mtyp240-faqs-questions-with-answers/page-1 Jeff Updated and at the top of this forum now 1 Link to post Share on other sites More sharing options...
wosamko Posted August 9, 2018 Author Share #25 Posted August 9, 2018 Solution for Battery ?! I found on amazon "CableDeconn USB to 5.5 mm/2.1 mm 5 Volt DC Barrel Jack Power Cable" on this link https://www.amazon.com/CableDeconn-Volt-Barrel-Power-Cable/dp/B012VLKXKM/ref=sr_1_5?ie=UTF8&qid=1533799511&sr=8-5&keywords=usb+to+laptop+power+cable Can I use the cable to connect the charger to the power bank safely. It might be better than using the car port?! So no need for extra batteries Link to post Share on other sites More sharing options...
jaapv Posted August 9, 2018 Share #26 Posted August 9, 2018 A car is 12V, USB is less than half at 5V. Even if it would work after a fashion, it is likely that it will take ages to charge a battery. What is the problem with using the 12V socket in your car? I would be rather nervous about having a single battery as well. Assuming that you travel by plane from time to time, can't you buy a couple of batteries in the tax-free at the airport (pre-order, of course)? How did you solve the problem for your Nikon? 1 Link to post Share on other sites More sharing options...
wosamko Posted August 9, 2018 Author Share #27 Posted August 9, 2018 Advertisement (gone after registration) A car is 12V, USB is less than half at 5V. Even if it would work after a fashion, it is likely that it will take ages to charge a battery. What is the problem with using the 12V socket in your car? I would be rather nervous about having a single battery as well. Assuming that you travel by plane from time to time, can't you buy a couple of batteries in the tax-free at the airport (pre-order, of course)? How did you solve the problem for your Nikon? In the past Qatar's customs allow importing batteries so I could buy extra batteries for Nikon. Regarding charging from the car; on trips I rid a tour bus and there is no car sockets! I will check regarding pre-order - Airport. Or I might buy 2 batteries at the countries Leica's dealers Anyhow, Thanks Jaap Link to post Share on other sites More sharing options...
Photon42 Posted August 9, 2018 Share #28 Posted August 9, 2018 In the past Qatar's customs allow importing batteries so I could buy extra batteries for Nikon. Regarding charging from the car; on trips I rid a tour bus and there is no car sockets! I will check regarding pre-order - Airport. Or I might buy 2 batteries at the countries Leica's dealers Anyhow, Thanks Jaap I was looking for a USB charging method myself, as I found an USB charger for my CL which I found super convenient. Leica should add a connector to their chargers, IMHO. Found this one, but did not yet order it. Some Powerbanks actually put out quite some juice. So even transformed to 12V it just do the job. On the spare battery side I would definitely buy a second one, and if it is only for reducing the risk. The M10 does eat the Battery relatively quickly - depends on usage pattern, of course. Just do not expect something like 700 frames. if will be much lower. 1 Link to post Share on other sites More sharing options...
