pmendelson Posted July 30, 2018 Share #1 Posted July 30, 2018 Advertisement (gone after registration) I am a flash noobie, and am looking for the simplest portable solution for an off-camera flash for the M10 and Q, for those occasions where I would like to hold the flash off to the side when shooting on the street, friends, etc. Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted July 30, 2018 Posted July 30, 2018 Hi pmendelson, Take a look here Simple off-flash solution for M10 and Q for casual use?. I'm sure you'll find what you were looking for!
UliWer Posted July 30, 2018 Share #2 Posted July 30, 2018 Perhaps not too elegant but works well with Leica SF 24 an SF 40: https://www.l-camera-forum.com/topic/286474-using-nikon-off-camera-flash-cables/ Link to post Share on other sites More sharing options...
jeremyk Posted July 30, 2018 Share #3 Posted July 30, 2018 You can buy really cheap radio triggers, like the CowboyStudio models. Put the transmitter on your camera, the receiver on the flash foot. They arent huge, and work mostly. Link to post Share on other sites More sharing options...
sillbeers15 Posted July 31, 2018 Share #4 Posted July 31, 2018 If your application is to apply fill-in light via OCF way on focal length no longer than 50mm. The simplest & cheapest way is to connect your flash off camera via a Nikon compatible cord while you shoot. You can hold the camera with your right hand and flash in left and typically reduce your flash power by -0.2EV for a more natural fill light on your subject. As M10 require both hands to manually focus, you can get a simple selfie stick with a wrist strap to lock your flash on your left hand while you focus before the shoot. Alternatively there is a low cost Q20 Manual Flash with a Guide number of 20 which can go off camera with a very compact trigger which you can adjust the flash intensity from the remote trigger for convenience and it is low cost. But the GN20 is kind of limited in range. Link to post Share on other sites More sharing options...
sillbeers15 Posted July 31, 2018 Share #5 Posted July 31, 2018 For a mobile and flexible set up, I mounted two SF60s on an extendable boom stick (up to 1.6m) as my off camera flash set up as shown below. Mobile Twin Off Camera Flash Set-up (Leica SF60 / SF C1) by sillbeers15 The following pics is an example of using the twin flash mobile OCF set up I’ve described above as you can see in the subjects’ twin light reflection in the eyes. Heresa & Isabelle II by sillbeers15 1 Link to post Share on other sites More sharing options...
