Louis Champan Posted July 11, 2018 Share #1 Posted July 11, 2018 Advertisement (gone after registration) I'm trying to find a simple and small flash to carry along with my Q for when the occasion arises. This little Fuji system seems like it might just do the trick, even though it's all manual. Anyone have any experience with using this flash on their Q? Link to post Share on other sites More sharing options...
Advertisement Posted July 11, 2018 Posted July 11, 2018 Hi Louis Champan, Take a look here Using Fuji EF-X20 flash with your Q . I'm sure you'll find what you were looking for!
Leica Guy Posted July 12, 2018 Share #2 Posted July 12, 2018 (edited) I had one early on when I acquired the Q. It works as a fill flash. As I remember it has AAA batteries. Its small which is good and bad. I ended up then with the Leica SF-26 and later I upgraded to the SF-40. I’m finally satisfied with the SF-40. It’s definitely much larger, but it uses AA batteries and I can tilt the flash and bounce the light. Its a personal preference based upon my use model. I do like it. Edited July 12, 2018 by Infiniumguy Link to post Share on other sites More sharing options...
bherman01545 Posted July 12, 2018 Share #3 Posted July 12, 2018 I like the Metz 34 CS-2 Digital. For a non-dedicated flash, with three auto F/Stops, full manual and an optical slave function, it is hard to beat. You can pick one up for less than $100.00. It is compact and powerful and uses 2xCR2 Lithium Batteries, so it recycles fast, and is Made in Germany. It also comes with a tele and wide diffuser, so it actually covers a 28mm wide-angle. I have one and have used these on Leica M, Q, Fujifilm and other cameras. It's a real 'sleeper' -Brad Link to post Share on other sites More sharing options...
Louis Champan Posted July 12, 2018 Author Share #4 Posted July 12, 2018 Thanks for the input, think I'll try one out at the camera store before making my decision. Link to post Share on other sites More sharing options...
Licheus Posted July 12, 2018 Share #5 Posted July 12, 2018 (edited) The Sunpak PZ20XD, the Panasonic PE-20S and the Nikon SB-30 are my trio of tiny flashes with AUTO mode. Truly tiny, anything else are at least a tad larger while being more powerful as well. The Sunpak is especially attractive since it has a easy-to-use slave mode and use readily available AAA batteries. Edited July 12, 2018 by Licheus Link to post Share on other sites More sharing options...
antigallican Posted July 12, 2018 Share #6 Posted July 12, 2018 I had to make the same decision recently and was very pleased with the Leica sf40. Bad news is the price :-( 1 Link to post Share on other sites More sharing options...
Leica Guy Posted July 12, 2018 Share #7 Posted July 12, 2018 Advertisement (gone after registration) Any brand starting with an “L” is expensive. Lexus, Lamborghini, Leica. :-) 2 1 Link to post Share on other sites More sharing options...
Louis Champan Posted July 13, 2018 Author Share #8 Posted July 13, 2018 The Sunpak PZ20XD, the Panasonic PE-20S and the Nikon SB-30 are my trio of tiny flashes with AUTO mode. Truly tiny, anything else are at least a tad larger while being more powerful as well. The Sunpak is especially attractive since it has a easy-to-use slave mode and use readily available AAA batteries. Thank you I appreciate your respond. But I do have a question, are you stating that those flash units you reference to are compatible with the Leica Q? I was not aware that any flash unit other than a Leica could be used in the Auto Mode. Link to post Share on other sites More sharing options...
Yoki Posted July 13, 2018 Share #9 Posted July 13, 2018 Any brand starting with an “L” is expensive. Lexus, Lamborghini, Leica. :-) So do Lucy and Linda in my case.. 1 Link to post Share on other sites More sharing options...
Leica Guy Posted July 13, 2018 Share #10 Posted July 13, 2018 So do Lucy and Linda in my case.. :-) Link to post Share on other sites More sharing options...
yulinn Posted July 20, 2018 Share #11 Posted July 20, 2018 I like the Metz 34 CS-2 Digital. For a non-dedicated flash, with three auto F/Stops, full manual and an optical slave function, it is hard to beat. You can pick one up for less than $100.00. It is compact and powerful and uses 2xCR2 Lithium Batteries, so it recycles fast, and is Made in Germany. It also comes with a tele and wide diffuser, so it actually covers a 28mm wide-angle. I have one and have used these on Leica M, Q, Fujifilm and other cameras. It's a real 'sleeper' -Brad Just curious, what adapter do you you use to attach the Metz to the Q? Is it the same for the Fuji? Link to post Share on other sites More sharing options...
mike3996 Posted July 24, 2018 Share #12 Posted July 24, 2018 (edited) I'm trying to find a simple and small flash to carry along with my Q for when the occasion arises. This little Fuji system seems like it might just do the trick, even though it's all manual. Anyone have any experience with using this flash on their Q? Look up BigHeadTaco from Youtube. He made a video with this exact combo and he tested if the flash syncs up to 1/2000 s (it does). EF-X20 being all manual there is zero issues with using it with Q. If you are willing to go manual, the options are plentiful. I got myself a Meike MK320 which also acts as all-manual for Q. Not bad, considering it can be had new for 50 eur, shipped. (But it's 200 g (double the weight of Fuji EF-X20) and I don't want to carry it with me) :{ Edited July 24, 2018 by mike3996 Link to post Share on other sites More sharing options...
