CptSlevin Posted June 30, 2018 Author Share #21 Posted June 30, 2018 Advertisement (gone after registration) There are half cases with battery doors and tripod screw mounts available that replace your bottom plate and contain a magnet that tricks the camera into thinking the base plate is present. One of those will do the trick. My favorite is the Arte di Mano version but I’ve seen others that should do the job for your application, as long as you are ok with the long exposure limitations of the M10 already mentioned. You're great, thanks mate! Link to post Share on other sites More sharing options...
Advertisement Posted June 30, 2018 Posted June 30, 2018 Hi CptSlevin, Take a look here M10 for Astrophotography. I'm sure you'll find what you were looking for!
Ron Weissman Posted June 30, 2018 Share #22 Posted June 30, 2018 The latest (6/29) M10 firmware upgrade allows 4 minute exposure at base ISO. While not competitive with the best, this is still a welcome upgrade. 1 Link to post Share on other sites More sharing options...
jmahto Posted July 1, 2018 Share #23 Posted July 1, 2018 (edited) Yeah! I saw it and also the comment with a case is an interesting set Now I need to understand what is LENR and how to bypass it. My max exposure time is 30 seconds. Am I right that after a shot it will take another 30 seconds to make a "black shot" in order to create one shot with such exposure? I use M240 (which has the same black shot after each exposure) for star trail frequently. I find it more convenient than my Sony(better wide lens wide open, easier focusing than Sony). 30 sec shot with 30 sec gaps don’t create any problem in stacking and final trails look ok. In fact I do get gaps due to removing airplane streaks but even then trails are fine. It is the overall aesthetics that matter. Try it and see if you like the result. No point theoretically speculating. I also find longer than 30 min unnecessarily for good looking Star trails. This is why battery change during shoot is unnecessary. Just take the camera out and give it a try. Edited July 1, 2018 by jmahto 1 Link to post Share on other sites More sharing options...
Macberg Posted July 31, 2018 Share #24 Posted July 31, 2018 So, hello guys! I am eager to purchase M10, as I have a deep passion for Milky Way photography and making timelapses about them and I am ready to switch from Canon to Leica, BUT! If I put Leica M10 on a tripod, I won't be able to change battery and if it goes off, I will have to unmount camera from a tripod and in this case my timelapse won't be constant Are there any plates for M10, which allow to change battery without unscrewing camera from a tripod? Thanks in Advance! How about that: http://www.luigicases.com/a000-M-Mates-Battery-SD-change.htm Link to post Share on other sites More sharing options...
eraydinc Posted August 12, 2018 Share #25 Posted August 12, 2018 My Astrophotography with Leica M10. Voigtlander 21mm. f/4 45sec 800 ISO. Model is me. I used M10 app for realese. https://500px.com/photo/269194349/l-by-eray-dinç?ctx_page=1&from=user&user_id=590954 Link to post Share on other sites More sharing options...
darylgo Posted August 13, 2018 Share #26 Posted August 13, 2018 This will get you close, get a plate with a lip, I use the Markins PG-30u. Push the lip fully against the front or back of the camera. When you mount the plate on the tripod clamp push the plate to one side so it's lined up with the edge of the clamp, or use a hard stop such as a ruler held against the clamp and put the plate there. Some clamps have screws that act as a safety, this will serve the same purpose. I've used this method to keep the camera consistently positioned with subjects that may not be as demanding as you require but additional steps could be devised to make this very precise using an indexing material in the clamp to push the plate against. The RRS plate may offer a workaround also: https://www.bhphotovideo.com/c/product/1337704-REG/really_right_stuff_bm10_base_plate_base_plate_for_leica.html/?ap=y&gclid=Cj0KCQjwtb_bBRCFARIsAO5fVvFJcbBGDlRaqVrLwrH1DGiLT9554NyDbUmIuqaLDZOTZ52BIfr36o8aAiCAEALw_wcB My M240 has yielded great Milky Way Images, the M10 should be better. Link to post Share on other sites More sharing options...
Likaleica Posted August 13, 2018 Share #27 Posted August 13, 2018 Advertisement (gone after registration) Last night for the Persied meteor shower and the new moon I compared the M10 to the H1D. In terms of noise and sharpness the M10 with 30 Cron Asph blew away the H1D with the 30mm lens. Also, I shot both at f/4, ISO 6400, 8 secs. The M10 had virtually NO NOISE. I didn't use the noise reduction slider at all. The H1D is all noise. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285907-m10-for-astrophotography/?do=findComment&comment=3571879'>More sharing options...
Buck777 Posted July 31, 2024 Share #28 Posted July 31, 2024 On 6/26/2018 at 2:50 AM, pgh said: I really couldn't imagine much of a worse primary use for a Leica than long exposure, astro photography. They simply aren't designed for what this type of use and while it's possible to some degree (not to get around your tripod problem), it's really downgrading from what you have for this specific type of work. I get why you want to ditch your Canon, but get a Sony or Nikon. Or if you have that $ to part and it's burning a hole in your pocket get a GFX or X1D. Wish you’d told me that before I took some on my Q2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 10 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285907-m10-for-astrophotography/?do=findComment&comment=5454706'>More sharing options...
Mikep996 Posted August 5, 2024 Share #29 Posted August 5, 2024 (edited) WOW! Impressive!!! Be nice to know specifics - camera settings AND location...I'm guessing nowhere near city lights! Edited August 5, 2024 by Mikep996 Link to post Share on other sites More sharing options...
smkoush Posted August 18, 2024 Share #30 Posted August 18, 2024 M10, 60s, ISO 400, 35mm Summilux-M ASPH (FLE) @ f/1.4, on a star tracker. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285907-m10-for-astrophotography/?do=findComment&comment=5485525'>More sharing options...
Osirix Posted September 8, 2024 Share #31 Posted September 8, 2024 On 7/31/2024 at 3:02 PM, Buck777 said: Wish you’d told me that before I took some on my Q2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Very impressive !! What star tracker, if any, have you used? Link to post Share on other sites More sharing options...
Buck777 Posted September 20, 2024 Share #32 Posted September 20, 2024 Have the Q2, and like the M10 ( which I’ve just brought ) it has iso restrictions, even more than the M10. It only allows 8 seconds at iso 1600. i initially thought this was ridiculous, but it actually worked. For those on here saying the Leica isn’t good for Astro, you simply aren’t trying. It’s very good. I’ve heard the iso restrictions are to prevent hot pixels, but obviously Leica never say Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 5 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/285907-m10-for-astrophotography/?do=findComment&comment=5619516'>More sharing options...
Michael Jones Posted December 5, 2024 Share #33 Posted December 5, 2024 One awesome photograph with a Q2. You must have a very dark location and the seeing that night was perfect. Well done! Link to post Share on other sites More sharing options...
Stevejack Posted December 27, 2024 Share #34 Posted December 27, 2024 I was horrified the first time I took my brand new M10 Monochrom out for some long exposure astro shots. On paper the monochrom sensor and some of the new fast lenses should be brilliant for milky way photography but the firmware just ruins it. No way to turn off LENR and limited exposure times.... crazy. Plus the Leica lenses are just not good for astro work. Even my 50mm APO was a disappointment, lots of aberrations wide open which is a shame for such an expensive lens. They are brilliant for their size, but they do make sacrifices to be as small as they are. Link to post Share on other sites More sharing options...
