Joakim Posted May 11, 2018 Share #1  Posted May 11, 2018 Advertisement (gone after registration) Hi  Today when I was out shooting with my S-006 and 120 APO I couldn't focus the lens all the way to infinity, first I was very confused but then I saw that it was the adapter for my Lee filter holder that was causing this since it has a larger outer diameter than the lens.  So my question is if anyone here is using the Lee filter system (100mm) together with there Leica S and if you have a solution to this problem?  I was thinking that maybe it would work with a step-up ring (and a wider adapter) to create some extra space between the lens and the adapter.  Joakim Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2018 Posted May 11, 2018 Hi Joakim, Take a look here 120 APO and Lee filter system. I'm sure you'll find what you were looking for!
Photon42 Posted May 12, 2018 Share #2 Â Posted May 12, 2018 You can help yourself out of the situation by screwing on a plain 72mm ring. Get an old filter and remove the glass. Or - if you must, use a clear glass filter. Probably they made it flush to not put too much pressure on the drive train, when the lens is put up side down (and with a camera on top). I haven't found it really limiting so far, as I do only use filters for wide angle and sometimes the normal-ish focal lengths. 2 Link to post Share on other sites More sharing options...
Dsauro Posted May 12, 2018 Share #3  Posted May 12, 2018 I just purchased the Hitech-Formatt 100 mm filter kit. I have the same issue on my 120APO. I was able to find a 77-77 step spacer on eBay which I’m waiting to arrive. Basically it’s a doubled up step bring so that I can focus to infinity . I think the price was about $18 US. If it works, I will let you know . Best 2 Link to post Share on other sites More sharing options...
Joakim Posted May 13, 2018 Author Share #4 Â Posted May 13, 2018 Thanks guys! I'll try to find a step-up ring or make an empty filter ring. 1 Link to post Share on other sites More sharing options...
Guest Posted May 29, 2018 Share #5  Posted May 29, 2018 I’ve stopped using the Lee filter system. I get good results exposing for the hilights and recovering the shadows in PScc or stacking 3 images that have been shot at varring exposures  Neil Link to post Share on other sites More sharing options...
alan.y Posted May 30, 2018 Share #6 Â Posted May 30, 2018 You can help yourself out of the situation by screwing on a plain 72mm ring. Get an old filter and remove the glass. Or - if you must, use a clear glass filter. Probably they made it flush to not put too much pressure on the drive train, when the lens is put up side down (and with a camera on top). I haven't found it really limiting so far, as I do only use filters for wide angle and sometimes the normal-ish focal lengths. Â Another way to get a spacer at the same diameter is to buy a collapsible rubber lens hood and remove the rubber part. 1 Link to post Share on other sites More sharing options...
albertknappmd Posted February 9, 2019 Share #7  Posted February 9, 2019 Advertisement (gone after registration) Step up ring should work very well. Albert 😚 Link to post Share on other sites More sharing options...
Jeff S Posted February 9, 2019 Share #8  Posted February 9, 2019 2 hours ago, albertknappmd said: Step up ring should work very well. Albert 😚 He figured that out 9 months ago. Jeff Link to post Share on other sites More sharing options...
albertknappmd Posted February 10, 2019 Share #9 Â Posted February 10, 2019 better late than never.. Albert Link to post Share on other sites More sharing options...
