fishdrummer Posted July 6, 2007 Share #1 Â Posted July 6, 2007 Advertisement (gone after registration) I ordered the 60mm IR filter for my nocti but it doesnt fit. the lens was made in canada serial 2854171 (i think 1977) Leica tells me i need an E48 which they do not currently manufacture. It was suggested I go to B & W. I this correct? Has anyone here had this experience and a solution? thanks Link to post Share on other sites More sharing options...
Advertisement Posted July 6, 2007 Posted July 6, 2007 Hi fishdrummer, Take a look here Noctilux filter woes. I'm sure you'll find what you were looking for!
glenerrolrd Posted July 6, 2007 Share #2 Â Posted July 6, 2007 You need an E58 not a 48. Leica does not supply one. I found a Heliopan Digital which works fine. E58 seems to be a come size for Camcorders with CCD . I have the same Noctilux. The started with a 58mm filter then went to a 60mm as it was a standard size. Link to post Share on other sites More sharing options...
carstenw Posted July 6, 2007 Share #3 Â Posted July 6, 2007 There should be no problems with using another brand on a 50mm lens. I will personally likely get a B+W slim filter, which comes with its own lens cap. Link to post Share on other sites More sharing options...
glenerrolrd Posted July 6, 2007 Share #4 Â Posted July 6, 2007 I almost forgot would you like to sell me your 60mm filter? Link to post Share on other sites More sharing options...
egibaud Posted July 6, 2007 Share #5  Posted July 6, 2007 If you are looking for a coded Noctilux with its filter. My dealer in France has just received one.  If you want to contact Nicolas, he is an official Leica dealer as you can check on Leica's site. I've bought several lenses from him with no problem (he shiped the lenses internationaly to me)  murophoto@wanadoo.fr  MURO Photographie & Galerie SARL CENTRE CONSEIL LEICA diplômé Nicolas Muro, Master en photographie - EXCLUSIF LEICA - 79 cours National 17100 SAINTES - FRANCE - tel: (+33) 5 46 93 43 37 fax: (+33) 5 46 74 20 01 Link to post Share on other sites More sharing options...
fishdrummer Posted July 6, 2007 Author Share #6 Â Posted July 6, 2007 You need an E58 not a 48. Leica does not supply one. I found a Heliopan Digital which works fine. E58 seems to be a come size for Camcorders with CCD . I have the same Noctilux. The started with a 58mm filter then went to a 60mm as it was a standard size. Â this one? Â 65099792 B + W 58mm UV/IR Blocking #486 Wide Angle Slim Mount Glass Filter for Blocking Ultra Violet and Infrared Radiation Link to post Share on other sites More sharing options...
wlaidlaw Posted July 6, 2007 Share #7 Â Posted July 6, 2007 Advertisement (gone after registration) If you are in Europe, can I recommend Michael Huppert as being super-efficient with huge stocks of various filters. I ordered a 52mm B+W 486 on Tuesday - arrived here in France today. Willkommen bei Foto Huppert He is listing them at EUR 79 for the 58mm. Â Wilson Link to post Share on other sites More sharing options...
Samir Jahjah Posted July 6, 2007 Share #8 Â Posted July 6, 2007 You need an E58 not a 48. Leica does not supply one. I found a Heliopan Digital which works fine. E58 seems to be a come size for Camcorders with CCD . I have the same Noctilux. The started with a 58mm filter then went to a 60mm as it was a standard size. Â As well Leica does not supply IR Filter for the 50mm Asph 1.4 LHSA (which is 43mm). Do you know where to get one? Link to post Share on other sites More sharing options...
sean_reid Posted July 6, 2007 Share #9 Â Posted July 6, 2007 There should be no problems with using another brand on a 50mm lens. I will personally likely get a B+W slim filter, which comes with its own lens cap. Â Right, the difference in cyan drift isn't worth thinking about. Â Cheers, Â Sean Link to post Share on other sites More sharing options...
Samir Jahjah Posted July 6, 2007 Share #10  Posted July 6, 2007 Right, the difference in cyan drift isn't worth thinking about. Cheers,  Sean  Does it mean that on a 50mm, one could use IR filter with an uncoded lense?   Also, what is the difference between a infrared filter and a dark red infrared filter (B+W offers the 87C and a dark red 89B). Link to post Share on other sites More sharing options...
fishdrummer Posted July 6, 2007 Author Share #11  Posted July 6, 2007 If you are in Europe, can I recommend Michael Huppert as being super-efficient with huge stocks of various filters. I ordered a 52mm B+W 486 on Tuesday - arrived here in France today. Willkommen bei Foto Huppert He is listing them at EUR 79 for the 58mm. Wilson   thanks Wilson..im in the USA Link to post Share on other sites More sharing options...
carstenw Posted July 6, 2007 Share #12 Â Posted July 6, 2007 Samir, you need the B+W 486 filter, or something equivalent. The other ones are for other purposes. Some of them block visible light, letting only IR through. Link to post Share on other sites More sharing options...
Samir Jahjah Posted July 7, 2007 Share #13 Â Posted July 7, 2007 Samir, you need the B+W 486 filter, or something equivalent. The other ones are for other purposes. Some of them block visible light, letting only IR through. Â Thanks. Link to post Share on other sites More sharing options...
sean_reid Posted July 7, 2007 Share #14  Posted July 7, 2007 Does it mean that on a 50mm, one could use IR filter with an uncoded lense?  Also, what is the difference between a infrared filter and a dark red infrared filter (B+W offers the 87C and a dark red 89B).  Yes, coding is really optional with a 50 - even with an IR-cut filter. The filters you'd want to use are either the Leica UV-IR cut filter, the B+W 486 filter or the Heliopan Digital filter.  Cheers, Link to post Share on other sites More sharing options...
wlaidlaw Posted July 7, 2007 Share #15 Â Posted July 7, 2007 As well Leica does not supply IR Filter for the 50mm Asph 1.4 LHSA (which is 43mm). Do you know where to get one? Â Samir, Â Leica does do a 43mm filter, in silver only. However all the current batch have the threads cut wrongly, so if you do want a Leica one, I would wait a bit. Alternatively get a B+W - see my previous post for source. Â Wilson Link to post Share on other sites More sharing options...
wlaidlaw Posted July 7, 2007 Share #16  Posted July 7, 2007 thanks Wilson..im in the USA  Then I think you need PopFlash.Photo  Wilson Link to post Share on other sites More sharing options...
