brill64 Posted April 2, 2018 Share #1 Posted April 2, 2018 Advertisement (gone after registration) So this happened recently with my MM1 after returning from Wetzlar to have the corroded sensor swap : turn camera on & press shutter > "Attention - shutter fault" warning dialogue > camera locks up > turn off camera & switch it back on again > camera works flawlessly. After turning camera off for an extended period, situation repeats over. I'm reluctant to go through the whole process of returning it because it works & of course, lovely new sensor but away it must! Eventually anyways.. Link to post Share on other sites More sharing options...
Advertisement Posted April 2, 2018 Posted April 2, 2018 Hi brill64, Take a look here "Attention - Shutter Fault" warning. I'm sure you'll find what you were looking for!
Gobert Posted April 2, 2018 Share #2 Posted April 2, 2018 (edited) Send them an email for advice and, if return is not necessary, don’t throw the reply away but store it carefully. Edited April 2, 2018 by Gobert 1 Link to post Share on other sites More sharing options...
a.noctilux Posted April 2, 2018 Share #3 Posted April 2, 2018 Maybe the battery ? End-of-life or nearly battery can be the cause: not enough power to drive the shutter. 2 Link to post Share on other sites More sharing options...
brill64 Posted April 3, 2018 Author Share #4 Posted April 3, 2018 Maybe the battery ? End-of-life or nearly battery can be the cause: not enough power to drive the shutter. I will check and had not thought of this. thank you! Link to post Share on other sites More sharing options...
bideford Posted April 3, 2018 Share #5 Posted April 3, 2018 I had this on my M8u - sent it to Wetzlar but they returned it with no issues found. Suspect it was either the memory card or battery as these items remained at home. James Link to post Share on other sites More sharing options...
brill64 Posted April 28, 2018 Author Share #6 Posted April 28, 2018 Maybe the battery ? End-of-life or nearly battery can be the cause: not enough power to drive the shutter. Very excited to report that this was the issue! All my batteries are very old & have been recharged many times. It has taken me three weeks to source a new M8 battery so my apologies for the delay in responding but now no need to return the camera to Wetzlar. Thank you, a.noctilux :) Link to post Share on other sites More sharing options...
a.noctilux Posted April 28, 2018 Share #7 Posted April 28, 2018 Advertisement (gone after registration) You are welcome. I'm glad that my experience helped you. Batteries and memory cards are the "less reliable" in digital long term use. 1 Link to post Share on other sites More sharing options...
