Jdphoto Posted March 19, 2018 Share #1 Â Posted March 19, 2018 Advertisement (gone after registration) I'm curious if one can adjust the brightness on the EVF and center the AF recticle with a push of the center button on the control pad? Sometimes in bright snow the increase in brightness would be helpful when determine exposure. Thank you. Link to post Share on other sites More sharing options...
Advertisement Posted March 19, 2018 Posted March 19, 2018 Hi Jdphoto, Take a look here EVF brightness and AF center point. I'm sure you'll find what you were looking for!
nspur Posted March 20, 2018 Share #2 Â Posted March 20, 2018 I'm curious if one can adjust the brightness on the EVF and center the AF recticle with a push of the center button on the control pad? Sometimes in bright snow the increase in brightness would be helpful when determine exposure. Thank you. There doesn't appear to be any shortcut to center the AF point. Link to post Share on other sites More sharing options...
jaapv Posted March 20, 2018 Share #3 Â Posted March 20, 2018 AF center point discussion here please: Â Â https://www.l-camera-forum.com/topic/282908-af-on-leica-please-listen/?do=findComment&comment=3484052 Â And here: Â Â https://www.l-camera-forum.com/topic/279113-cl-firmware-update/ Link to post Share on other sites More sharing options...
Jdphoto Posted March 21, 2018 Author Share #4 Â Posted March 21, 2018 Â Â AF center point discussion here please: Â Â https://www.l-camera-forum.com/topic/282908-af-on-leica-please-listen/?do=findComment&comment=3484052 Â And here: Â Â https://www.l-camera-forum.com/topic/279113-cl-firmware-update/ There is no AF mode under the Fn button, so I guess there is no way to center the AF. Normally this wouldn't be an issue, but I mistakenly moved the AF target all the way to one side. In bright sunlight this isn't so obvious through the EVF, but if I could increase the brightness, it might be useful. Link to post Share on other sites More sharing options...
Jdphoto Posted March 23, 2018 Author Share #5 Â Posted March 23, 2018 Â Ok, found the AF mode, so will add it to the Fn. Thanks. Link to post Share on other sites More sharing options...
