Since I got into the M246 quite late and without any research prior to buying. I have just recently found out that it is only a 12bit DNG machine.... That explain quite bit about the quality it provides me as it is quite different from my experience with the CCD MM I had a couple of years back before the CCD corrosion fiasco was announced (which I sold it off the minute they announce it as I don't get any support in China).
So is this a big issue with owner of the M246 as well as CCD MM? Is there anyway in post to eliminate the difference, such as any technique or parameters i can play with in LR or Silverefex...
For me, it's no way I can use the CCD MM anymore as I am pairing this M with a Cambo Actus when I am doing large stitching Landscape and I need to have LV...
Any help will be appreciated. Thank you....
Wait, before anything, is the CCD MM a 14bit DNG?
x
