jwestman Posted February 4, 2018 Share #1 Posted February 4, 2018 Advertisement (gone after registration) I am vacationing in Mexico. Each morning mist and low clouds settle over the mountains. I am struggling trying to capture them. The results don't match what I see. Any suggestions for settings or post processing to make the mist more dramatic? Thanks for the help! j Link to post Share on other sites More sharing options...
Advertisement Posted February 4, 2018 Posted February 4, 2018 Hi jwestman, Take a look here Mist? . I'm sure you'll find what you were looking for!
Leica Guy Posted February 4, 2018 Share #2 Posted February 4, 2018 Maybe under expose. Or use a 6 stop ND for longer exposite. Don’t know. I’d try those if it were me. 1 Link to post Share on other sites More sharing options...
uffehagen Posted February 5, 2018 Share #3 Posted February 5, 2018 Maybe under expose. Or use a 6 stop ND for longer exposite. Don’t know. I’d try those if it were me. Mist will fool your autoexposure to believe the scene is too bright, and will adjust so you will get an underexposed image. Probably you should compensate 1-2 stops Link to post Share on other sites More sharing options...
Leica Guy Posted February 5, 2018 Share #4 Posted February 5, 2018 Mist will fool your autoexposure to believe the scene is too bright, and will adjust so you will get an underexposed image. Probably you should compensate 1-2 stops Wise advice. Thanks. I learned a long time ago NEVER use flash when there’s a mist unless you want special effects. Link to post Share on other sites More sharing options...
jaapv Posted February 5, 2018 Share #5 Posted February 5, 2018 Also, when postprocessing, you can emphasize foggy conditions by shoving the "dehaze" slider in the "wrong" direction. Link to post Share on other sites More sharing options...
frame-it Posted February 5, 2018 Share #6 Posted February 5, 2018 i'd shoot 3 shots // +-2EV bracket..and put the pics together in photoshop or lightroom I am vacationing in Mexico. Each morning mist and low clouds settle over the mountains. I am struggling trying to capture them. The results don't match what I see. Any suggestions for settings or post processing to make the mist more dramatic? Thanks for the help! j Link to post Share on other sites More sharing options...
