Universalb50 Posted January 23, 2018 Share #1 Â Posted January 23, 2018 Advertisement (gone after registration) I have a lens that was recoated years ago (Selten), and remains "perfect'. Can I assume the recoated lens will be comparable to an original in resolution? Link to post Share on other sites More sharing options...
Advertisement Posted January 23, 2018 Posted January 23, 2018 Hi Universalb50, Take a look here Recoated collapsible M summicron 50/2.0. I'm sure you'll find what you were looking for!
spydrxx Posted January 23, 2018 Share #2 Â Posted January 23, 2018 The coating shouldn't really alter the resolution, but rather the contrast and flare resistance. 2 Link to post Share on other sites More sharing options...
TomB_tx Posted January 24, 2018 Share #3 Â Posted January 24, 2018 Any polishing to re coat, or care in reassembly can affect resolution. Link to post Share on other sites More sharing options...
spydrxx Posted January 24, 2018 Share #4 Â Posted January 24, 2018 Tom's right. I made my comments assuming no polishing of the glass was necessary, merely recoating. Link to post Share on other sites More sharing options...
Ecar Posted January 24, 2018 Share #5 Â Posted January 24, 2018 It depends on what one calls "comparable". For example, several years ago, I sent an old Summar to Peter Grisaffi for a CLA. The lens had a sentimental value for me and the front element showed numerous, thin surface scratches. Upon advice from Peter and the company who did the glass work for him, we decided to have the front element polished and recoated. My understanding was that the effect of the polishing process using modern technology would remove only a negligible amount of the glass surface and that it would, if anything, correct the irregularities of glass produced using industrial processes from decades ago. I guess that what I'm saying is that old lenses of the same type are not strictly comparable between them due to production variances and that polishing the front element only is unlikely to alter the resolution of a lens in a way that would make it "different" from its peers. On the other hand, while recoating per se does not affect resolution, it has a fairly dramatic effect on the rendering of a lens - indeed by improving contrast and flare resistance. That Summar is now probably a significantly "better" lens than it was out of the box - but has arguably lost some of its character. 1 Link to post Share on other sites More sharing options...
