Astropap Posted January 21, 2018 Share #1 Posted January 21, 2018 Advertisement (gone after registration) For those of you who select DNG + Monochrome jpg, which settings do you like the best for the jpg? I'd like to achieve similar results to what I get from the high contrast B&W in the X Vario. Thanks Link to post Share on other sites More sharing options...
Advertisement Posted January 21, 2018 Posted January 21, 2018 Hi Astropap, Take a look here B&W settings? . I'm sure you'll find what you were looking for!
SonomaBear Posted January 21, 2018 Share #2 Posted January 21, 2018 I set contrast and sharpness to medium high. Then add a bit of grain in LR. Reminds me of my Tri-X days! Link to post Share on other sites More sharing options...
Astropap Posted January 21, 2018 Author Share #3 Posted January 21, 2018 Thank you. I'll give those settings a try. Link to post Share on other sites More sharing options...
Astropap Posted January 23, 2018 Author Share #4 Posted January 23, 2018 Another question, which I think was addressed in another thread but I can't find it. Is there a way to set the EVF to color when the JPG is set to monochrome? I'm going to be taking the camera out to the ski slopes and I often use manual focus. I'd like to be able to see the focus peaking colors. Thanks Amy Link to post Share on other sites More sharing options...
Astropap Posted January 23, 2018 Author Share #5 Posted January 23, 2018 OK -- I found the post about cycling through using the center button of the D pad and got the color view. However, I lose the level even though I have that setting turned on. Also lose the grid lines until I depress the shutter button. Any way to have the EVF be in color and keep the level and grid lines when I have the jpg setting on monochrome? Link to post Share on other sites More sharing options...
Leica Guy Posted January 23, 2018 Share #6 Posted January 23, 2018 (edited) Another question, which I think was addressed in another thread but I can't find it. Is there a way to set the EVF to color when the JPG is set to monochrome? I'm going to be taking the camera out to the ski slopes and I often use manual focus. I'd like to be able to see the focus peaking colors. Thanks Amy I’m not aware of any way to set the camera up as you want. I set mine to jpeg saturation - monochrome. That way in manual focus the focus peaking shows up in color and is easy to see. Live View - Level gauge on. Grid - on. There are four display modes selectable from the center button on the controller. On my camera two of the settings show the level. Two do not. Edited January 23, 2018 by Infiniumguy Link to post Share on other sites More sharing options...
Astropap Posted January 23, 2018 Author Share #7 Posted January 23, 2018 Advertisement (gone after registration) Hmmm. I'm going to cycle through those settings again. thanks for responding Link to post Share on other sites More sharing options...
marchyman Posted January 24, 2018 Share #8 Posted January 24, 2018 I'd like to be able to see the focus peaking colors. Thanks Amy You still see the focus peaking colors when the camera jpg setting > saturation is set to monochrome Sometimes it's easier to see the peaking that way. At least its easier for me when using red as the peaking indicator color. Link to post Share on other sites More sharing options...
uffehagen Posted January 24, 2018 Share #9 Posted January 24, 2018 OK -- I found the post about cycling through using the center button of the D pad and got the color view. However, I lose the level even though I have that setting turned on. Also lose the grid lines until I depress the shutter button. Any way to have the EVF be in color and keep the level and grid lines when I have the jpg setting on monochrome? If you are in monochrome, and cycle through settings with the centre button, you will get one setting showing colours and no grid. Thats when you hit video setting. Link to post Share on other sites More sharing options...
Astropap Posted January 24, 2018 Author Share #10 Posted January 24, 2018 Thanks. I set it back to monochrome but with red focus peaking. I think that should be easiest to see outdoors against snow. Link to post Share on other sites More sharing options...
