I have reset my MM number and it turned into the standard L100000 first number.
But how can I make that unique? I want the MM frames to be called MM witha serial number starting with e.g. 2 just to distinguish them from other L100n frames (I have several of those..)
I tried making a folder with the name MM but the picture number stays L100000n etc.
The manual does not help met out.
Hope someone has an answer to this newbie question  :(
albert
albert
Menu/Setup/
Go to page 4
Image Numbering/Set/ Change filename
Edit: this is the M246 setting, no idea if this is identical in the MM1 menu
Edited by mich
Just to clarify, you have 4 digits you can use for your filename, so in your case you start with MM01. After 9999 actuations(MM01-9999) the camera software will switch to MM02-0001 and so on. You will always have a unique number.
You can of course start with any number. I don't know what will happen when you use all for digits for letters, how the software will react, haven't tried that.
Another option: If you want to switch numbering within a given theme(MM05), maybe you reached # MM05-0478 and you want to start a new series within the MM05 theme, you can rename an image to MM05-1000 and the camera will start the new count at MM05-1001
Just realized that I made a complete fool out of myself! I confused file numbers with folder numbers. After 9999 actuations the camera software doesn't rename the file prefix, it creates a new folder with the next number. The file count starts really at 0001 again. So the only option is a manual change of the prefix just before you reach the maximum count(or anytime earlier).
In your case with your prefix MM you can use the 2 additional digits for any combination of letters and numbers x10000.
I apologize for creating some confusion! Sometimes it is better to rethink a problem more carefully than to post prematurely!
Cheers
Edited by mich
Thanks for the effort; the instructions you gave comply with those from the M240.
When I bought my MM1, used, the sequence was somewhere at L135 and happily progressed to L139 before it got its sensor replaced - and the number sequence reset.
What sort of works is:
Change the folder name on the PC to 110LEICA and the last image to L1100008; the ne next image is L1100009.
Changing the prefix to M or MM does not work unfortunately
Edited by Alberti
So the MM1 has no option to change file/folder-names in camera. I wasn't sure which one you were referring to. Leica implemented this feature in the MM2, so they obviously considered it as being useful. I don't know whether there were any MM1 firmware updates after the MM2 hit the market but that would have definitely been a useful feature.
Sorry I couldn't be more helpful!
