jhluxton Posted November 26, 2017 Share #1 Posted November 26, 2017 Advertisement (gone after registration) Spotting a good "Black Friday" deal on a Leica ever ready case for an M I bought one. It arrived yesterday and is a distinct improvement on the budget neoprene case / body protector I bought with the camera. However, I am puzzling how to separate the front of the ERC from the body. There appears to be a press stud - but applying usual force does not separate the front from the base. Looking under the flap there appears to be a metal fixing but I am not sure if I should pull the two apart or do something else. Obviously I don't want to damage it! The only info in the case was a note about possible discolouration of the leather. Can someone tell me what to do? I have tried googling and not found an answer though I have seen a picture of the two sections separated. Thanks John Link to post Share on other sites More sharing options...
Advertisement Posted November 26, 2017 Posted November 26, 2017 Hi jhluxton, Take a look here Leica M240/262 ERC query. I'm sure you'll find what you were looking for!
bocaburger Posted November 29, 2017 Share #2 Posted November 29, 2017 The case bottom is a keyway. The stud in the case top slides/snaps toward the front (or back, I forget) and then comes free. Link to post Share on other sites More sharing options...
jhluxton Posted December 13, 2017 Author Share #3 Posted December 13, 2017 The case bottom is a keyway. The stud in the case top slides/snaps toward the front (or back, I forget) and then comes free. Thanks, I did actually fathom it out in the end. Having had quite a few ERCs on 35mm cameras this is the first time I have encountered one like this. Glad I didn't force it! Link to post Share on other sites More sharing options...
bocaburger Posted December 15, 2017 Share #4 Posted December 15, 2017 I've got OEM ERC's for my M4's which both have that keyway design. I think (not sure) the ones for my Nikon FTn's are like that also. The reason I guess is for those who use the cases as intended, with top part attached and hanging, it's a lot harder to have it unintentionally detach and fall off, compared to a simple snap. Link to post Share on other sites More sharing options...
