Old slave cabins
Photoskeptic
Built in the 1850's. These are on the grounds of the McLeod plantation on James Island across the Ashley River from Charleston, SC.
I shot this in DNG with a yellow filter, then converted to bw by desaturating in ACR 4.1. M8, 50 cron, ISO 320.
Thank you, Stuart. The secret is using a yellow filter to extend the DR. Ordinarily, a regular DNG shot would have blown out the sky highlights and you would not even see the clouds. The result looks pretty bizarre in color and it's not until it is converted does it look like intended. While I usually convert with Channel Mixer I had heard the newest ACR had some changes which would benefit bw so I gave it a shot (so to speak :D )
