DNG Only on card 1 & 2?
vladik
Easy to do. You need to make settings in two menus.
IMAGE menu:
Photo File Format set to DNG
SETUP menu:
Storage Options set to SD1=SD2
Thank you ramarren, what made it confusing for me is that the display in Storage option (top line) displays DNG+JPG on SD1=SD2 (Backup)
With Leica cameras, it is always best to just do the experiment.  The manual and the displayed information is sometimes misleading, although usually not wrong.
Good: you understand now that what this means is that the output of the camera's processing engine (IMAGE menu: Photo File Format) is separate from where it puts its products (SETUP menu: Storage Options). When you elect format to be DNG + JPEG, with v3 firmware you have the additional option to set the Storage to put the DNGs in one place and the JPEGs in another. :)
