Leica T Budget Macro
Last week I bought from Ffordes Photographic Ltd. for the grand sum of £99 a 1965 vintage Leitz 135/2.8 Elmarit R single cam lens with the intention using it with existing Leitz APO 2x extender as budget tele lens on the Leica T;  135 x 1.5 x 2 = 405mm FF equivalent.
Today decided to try the lens as a budget macro objective by utilising an equally vintage Leitz Elpro VIIa achromatic supplementary close up lens - previously purchased s/h for less than £10. The first photos illustrate the apparatus / methodology using a Gitzo tripod (in semi- ground level mode) , Lihhof ball head, Elicar focus slide, Lastolite reflector, and Leica STA 1 14636 Tripod Collar … latter is designed for the Leica APO Macro Elmarit R 100/2.8 but can be used with other lenses … and in this case is adapted to the Novoflex R to SL adapter (by wrapping a layer of self adhesive Velour around the adapter).
In the first two photos the lens hood is retracted to illustrate how the Elpro is screwed onto the lens' filter thread.
… apparatus set up in front of a common lizard habitat i.e. a rotting tree trunk on a local nature reserve
cont'd …
… and here are a few of the resultant photos of the Viviparous Lizards ...
Reasonably pleased with results so far and plan to return the site and try some closer views utilising R extension tubes.
Don't under-estimate ancient R lenses and Elpro lenses … they can offer a good budget means of creating close-up images in the field … but good apparatus support and a focus slide also help .. as does a decent reflector.
For those interested in finding out more about using Leitz Elpro lenses e.g. magnifications attainable with various R lenses, please consider obtaining Günter Osterloh's book: Excellence in Photography: Applied Leica Technique … which includes matrices detailing all the various Elpro lenses and their capabilities / specifications
Best wishes
dunk
For the small amount of close-up shooting I do, the Elpro VIIa more than suffices.  I previously used it on an X-Vario, and more recently managed to pair a couple of stepping rings so I can use it on my 55-135mm.   For budget macro I also have a couple of the old OUFRO 10mm rings (16469, I think) I used in the distant past; but much prefer the Elpro as it seems brighter and is easier to deploy.
There are other Leica T/TL system threads/posts with suggestions for using supplementary achromatic close-up lenses on TL zoom lenses:
https://www.l-camera-forum.com/topic/247554-close-up-filters-on-leica-t/?hl=marumi&do=findComment&comment=2851590   includes a Canon achromatic c/u lens and a list of Leitz Elpro c/u lenses
https://www.l-camera-forum.com/topic/242426-macro-on-the-t/?hl=marumi&do=findComment&comment=2782429 … includes Marumi c/u lenses and using Leica/Leitz ring combinations (extension tubes)
Camera/lens support(s) are of equal importance especially when working with smaller apertures requiring longer exposures … and a focus slide or focus rack makes focusing so much easier.
And for indoor table top c/u photography some enthusiasts prefer to work using a copy stand.
dunk
Best wishes
dunk
Dunk,
I am just as interested to ask where you found Lizards in the UK, in all my years I have never seen any?
Dunk,
Lizards are common and found throughout the UK. Try contacting your local Staffs Wildlife Trust groups / sites http://www.staffs-wildlife.org.uk/species/common-lizard … lizards should be visible at many conservation sites and nature reserves until late October before they hibernate for the winter.
dunk
