hdmesa Posted September 2, 2017 Share #1 Â Posted September 2, 2017 Advertisement (gone after registration) In case this happens to anyone else: Â After upgrading the firmware to 3.0, I set the storage option to split the DNG and JPEGs to separate cards; however, what was happening was DNG was going to Card 1, but JPEGs were going to both cards. After reformatting both memory cards, everything now works correctly. I don't know if I'm always supposed to reformat memory cards after a firmware update, but I will from now on. Link to post Share on other sites More sharing options...
Advertisement Posted September 2, 2017 Posted September 2, 2017 Hi hdmesa, Take a look here Reformat memory cards before "Split DNG / JPEG" works correctly. I'm sure you'll find what you were looking for!
scott kirkpatrick Posted September 3, 2017 Share #2 Â Posted September 3, 2017 This doesn't seem to be supposed to happen. Â Had the cards been formatted before you started? Â If they were fresh cards, did you format both of them? Â (Doing format 2 before format 1 is a good idea, since for some modes the last card formatted will be what you write to.) Link to post Share on other sites More sharing options...
ramarren Posted September 3, 2017 Share #3  Posted September 3, 2017 I've not had this problem. When I was doing beta testing, I had a second set of cards dedicated to that purpose. When fw 3.0 was released, I switched back to my usual set of cards which were still about half full, and set the option to split DNG and JPEG files. No problems at all. Link to post Share on other sites More sharing options...
