M Lens Construction
zeleny
Usually the lenses have an outside barrel of brass, and for non-rotating lenses, which include almost all recent ones there is an interior helicoid which is aluminum and then the innermost helicoid is again brass. For non-rotating lenses two sets of interlocking helicoids are necessary at minimum, i.e., three pieces.
Here's the MATE, for an extreme example: https://goo.gl/yBR6FL  The yellow pieces are brass, the white (or bright. pieces aluminum.
Even better, here's the MATE and the Summilux 50/1.4 ASPH. Note the metal colours again. The Summilux has of course a lot more complex construction than your 35mm Summicron due to its floating elements which require further helicoids. I'm sorry, but I couldn't find a section picture of your Summicron just now. Note that the 50/1.4 has a lens mount of brass, so that it can easily be chromed and thus hardened, even though the majority of the lens is aluminum. It's a demonstration of using appropriate materials.
Hello Henning,
Thank you.
The use of dissimiler metals to reduce problems such as friction & wear was invented by clock & watch makers at the beginning of clock making.
These are the same clock & watch makers who later invented what became: The automobile clutch, the bicycle chain & the mechanism that powers the Leica focal plane shutter
Best Regards,
Michael
