albertknappmd Posted June 17, 2017 Share #1 Posted June 17, 2017 Advertisement (gone after registration) I noticed that when I attach my 24mm lens to the 007 that the DOF indicator on the top of the camera does not work consistently. I have found that if I take lens off and then put it back on that the DOF indicator works for a while. There is no issue with the lens' spectacular performance in that while the DOF indicator is off the photograph produced is perfect.... Seems to me that it is a contact issue between camera and the specific lens as All other lens work fine. HOWEVER, the curious thing is that when I use the 24mm lens on my other 007, the 24mm DOF registers perfectly. THEREFORE, are we dealing with a contact issue on the 24 or the 007? Very strange.... Any suggestions... Thanks, Albert Link to post Share on other sites More sharing options...
Advertisement Posted June 17, 2017 Posted June 17, 2017 Hi albertknappmd, Take a look here DOF indicator malfunction . I'm sure you'll find what you were looking for!
Jeff S Posted June 17, 2017 Share #2 Posted June 17, 2017 Call your friends at Leica Miami. Jeff Link to post Share on other sites More sharing options...
albertknappmd Posted June 18, 2017 Author Share #3 Posted June 18, 2017 I did and lens going back to Wetzlar! Albert Link to post Share on other sites More sharing options...
xiaubauu2009 Posted June 21, 2017 Share #4 Posted June 21, 2017 I noticed that when I attach my 24mm lens to the 007 that the DOF indicator on the top of the camera does not work consistently. I have found that if I take lens off and then put it back on that the DOF indicator works for a while. There is no issue with the lens' spectacular performance in that while the DOF indicator is off the photograph produced is perfect.... Seems to me that it is a contact issue between camera and the specific lens as All other lens work fine. HOWEVER, the curious thing is that when I use the 24mm lens on my other 007, the 24mm DOF registers perfectly. THEREFORE, are we dealing with a contact issue on the 24 or the 007? Very strange.... Any suggestions... Thanks, Albert I have the same issue. But it occurs on all of my lens (24, 35, 70, 30-90, 100), so I deduced that it's a problem with the body.... Link to post Share on other sites More sharing options...
albertknappmd Posted June 24, 2017 Author Share #5 Posted June 24, 2017 My other lenses do not have the issue... It may be the CONTACT on your body that is at fault. Albert Link to post Share on other sites More sharing options...
