likealot Posted July 23, 2017 Author Share #21 Posted July 23, 2017 Advertisement (gone after registration) Can I ask, are the tripod heads interchangeable between brands? I've bought the MeFoto RoadTrip for nearly half the price on ebay and was wondering if I would be able to use heads from other brands on it in thefuture? Link to post Share on other sites More sharing options...
Advertisement Posted July 23, 2017 Posted July 23, 2017 Hi likealot, Take a look here Small, lightweight tripod recommendations? . I'm sure you'll find what you were looking for!
LocalHero1953 Posted July 23, 2017 Share #22 Posted July 23, 2017 Most heads that are detachable will have a standard bottom screw fitting which can be used with another tripod. Where they differ is in the attachment to the camera. The two common ones are the Arca-Swiss quick release fitting and the Manfrotto QR fitting, which are incompatible. Many manufacturers make Arca-Swiss compatible heads, but I think Manfrotto QR heads are only made by them. Both types require you to fit a QR plate (of the correct style) to the camera tripod screw. Having tried both, I would avoid Manfrotto and stick to Arca-Swiss. Mefoto has Arca-Swiss compatible heads and QR plates. Link to post Share on other sites More sharing options...
lucerne Posted July 23, 2017 Share #23 Posted July 23, 2017 Fortunately, you've bought an item that does have plate compatibility with Arca. BUT Did you pre-check? Here's what is published on the MeFoto site. "Precision Matched Q Series Ballhead Dual action heavy duty ballhead with Arca-Swiss style compatible quick release plate." Link to post Share on other sites More sharing options...
marchyman Posted July 24, 2017 Share #24 Posted July 24, 2017 The two common ones are the Arca-Swiss quick release fitting and the Manfrotto QR fitting, which are incompatible. Many manufacturers make Arca-Swiss compatible heads, but I think Manfrotto QR heads are only made by them. Both types require you to fit a QR plate (of the correct style) to the camera tripod screw. Having tried both, I would avoid Manfrotto and stick to Arca-Swiss. Mefoto has Arca-Swiss compatible heads and QR plates. I have a few pieces of gear that use the Manfrotto style QR mounts, i.e. the Manfrotto magic arm which I love. Since I use Arca-Swiss style plates on my cameras my solution was to create this: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It is a Manfrotto QR plate screwed into a generic Arca-Swiss style QR clamp. Total cost was about $15. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! It is a Manfrotto QR plate screwed into a generic Arca-Swiss style QR clamp. Total cost was about $15. ' data-webShareUrl='https://www.l-camera-forum.com/topic/273557-small-lightweight-tripod-recommendations/?do=findComment&comment=3322228'>More sharing options...
likealot Posted July 24, 2017 Author Share #25 Posted July 24, 2017 Fortunately, you've bought an item that does have plate compatibility with Arca. BUT Did you pre-check? Here's what is published on the MeFoto site. "Precision Matched Q Series Ballhead Dual action heavy duty ballhead with Arca-Swiss style compatible quick release plate." To be honest I didnt even realise that there were different style fittings. Thankfully it seems that I have made the right choice by chance considering that I was considering the Manfrotto tripods for a while. Link to post Share on other sites More sharing options...
