Custom lenses for S
ynp
Does anybody know a person or a company capable to mount some optical blocks into the S mount?
I happened to get several Rollei medium format optical blocks without a helicoid and wonder what can be done to adapt them to my camera. I have seen an adaptation with a Chinese iris and helicoid connected to a Mamiya-S adapter and I would like to get something similar.
One of my Rollei lenses has the iris diaphragm mechanics already installed, so it's easier to adapt.
Thank you.
Yevgeny
I asked a machine workshop to use the focusing helicord of a Hasselblad Distagon 4/50 C lens and made an adapter for Rollei SL66 lenses to use on Hasselblad V series cameras; thence with the help of a Leica S-adapter V, these SL66 lenses can be used on S cameras .................
I also asked Red Dot Camera to build an adapter for Rollei SL66 lenses on Leica S and retain full tilt-shift capability ..................
Wow!
Thank you very much. Impressive work. Would your machinist take orders?
I have the lens blocks from the Rollei 80mm Planar TLR and HFT 250 mm. and 500 mm. from the SL.
That T/S solution is very interesting. Thank you for sharing it.
