Got my Leica SL last week - have been trying to figure out how I can take long exposure shots in manual mode. Max I have been able to do is 60 seconds. Didn't find it in the manual either.
Any help will be really appreciated.
Hello Enbee,
what FW version are you running? After FW 2.0, you should be able to use Manual mode up to 30 minutes, and metering will work as normal (as opposed to bulb where you have to do your own calculations and keep the shutter open).
Best regards,
Vieri
Edited by Vieri
Thank You Vieri. I updated to FW 2.2 - but I was unable to get it to 30 min. I follow the following steps:
1. Switch to Manual Mode
2. Aperture to F22
3. Update shutter speed - I only get to 60 seconds
Is there something I am missing?
Thank You!
what do you mean by 'update shutter speed' ??
with 'M' set on the press/rotate rear dial and any shutter/iso set you can rotate the shutter speed selector anti-clockwise through all the speeds to 30minutes and then B
2. Aperture to F22
Thank You!
Manual mode
Aperture setting makes no difference.
Turn rear dial until you see B and than back off one. Should be 30 minutes.
If you really cannot get any longer exposure times, I'd bring the camera to Leica and have it checked.
Manual mode
As the gentlemen said. In M mode, you should be able to turn past 60 seconds no matter what your aperture is. Best regards,
Vieri
  • 1 month later...
Sorry for responding a tad bit late! But I went to Leica store and they helped me understand what needed to be done! Thank You all.
Sent from my iPhone using Tapatalk
  • 7 years later...
Am 2.7.2017 um 07:53 schrieb Enbee:
I find myself in the same situation: I need, for example, exactly 17, or 23, or 47 minutes exposure time, which unfortunately I can't set via the camera. How do I solve this with the app on my iPhone? I have seen the long exposure times of up to 60 minutes. Unfortunately, the steps are too big for me.
MIOPS Smart (and similar) will do the job, with Panasonic plug + adapter on the camera side, see eg post #14 here:
Edited by helged
