Hello,
I wanted to have some feedback on a potential issue I have with my Leica Q.
Sometimes when I focus and reframe, the camera refocuses at the moment I take the picture and I loose my original focus.
I'm just pushing the button from half way to final position.
I'm in AFS and 1 Point focus.
The thing which bothers me is that it does not happen all the time. I tested this with a friend's Q and it never happened on the numerous tries I did.
I think it started 1 week ago.
Does anyone experienced the same issue ?
Thank you !
While searching the forum for similar issues I stumbled upon this thread http://www.l-camera-forum.com/topic/264600-focus-lock-problem-with-flash/
The main difference here is that I have no external flash but a thumbs up (http://www.matchtechnical.com/Pages/ThumbsUpEPSQ.aspx) which is installed on the hot shoe.
So I'm wondering if there is a contact which could interfere on the focusing mechanism.
I will try putting a piece of paper between the camera and the thumbs up
Annoying indeed. As I mentioned, in my case the behavior was clearly related to using the Nikon flash. Without it, no issue, with it, always. Consistently. So this must be something else that manifests itself as the same behavior.
Please keep us informed on the proceedings, and good luck!
  • 1 month later...
  • 8 months later...
Hello,
Thank you !
I just purchased a used Q a few days ago, and have enjoyed using it so far.  However, I have experienced the same issue, and am wondering if anyone has gained any new insight?  It happens in AF-S, with single point mode.  It doesn't do it all the time, like others, I will half press to focus, recompose the scene, then as i press the shutter the camera refocuses on whatever is then in the focus area.  One thing that I'm wondering is if it actually has to do with the shutter button itself.  I feel like I've been able to get it to focus and hold focus by pressing to one side of the focus button, but if i press directly in the middle of the button, where my index finder usually hits, that is when it refocuses.  I'm wondering if the button is loosing contact, even though the focus area box continues to glow green, and the camera thinks the button is no longer half pressed.  I have a few days to send it back, so I'm wondering if anyone here has any additional insight.
Thanks
