M(240) not turning on
I have been using my 4 year old M(240) quite a lot this past week, often with Leica R adapter/60mm/EVF. It gave me a low battery/change battery warning so I did that but then it does not turn on again. There is no red light on rear of camera and nothing works......
I left the battery out overnight but it made no difference, has anybody seen this issue or will it be a trip to Wetzlar?
john
If you switch on and wait a few seconds do you see the framelines in the viewfinder and an sd message where shutter speed usually appears when you half press the shutter? Try a different SD card if so, could be corruption. Failing that, a trip to Leica I'm afraid (see my post from the weekend).
