leica1215 Posted March 22, 2017 Share #1  Posted March 22, 2017 Advertisement (gone after registration) I was considering the sf40 hence 64 I think is a bit too big, so I remember that some non leica branded flash will work with M, any others work with SL? Thanks   Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Advertisement Posted March 22, 2017 Posted March 22, 2017 Hi leica1215, Take a look here Any non leica brand flash work well with SL?. I'm sure you'll find what you were looking for!
geetee1972 Posted March 22, 2017 Share #2 Â Posted March 22, 2017 All Nikon mount flah units will work, they just won't offer TTL metering and output. Â The SF40 is clearly a rebrande Metz M400 and indeed, there is a version of this that at least purports to be compatible with Leica, meaning, I pressume, that it offers TTL metering and output: Â https://www.parkcameras.com/p/9353654P/flashguns-panasonic-fit/metz/mecablitz-m400-flashgun-for-olympuspanasonicleica Link to post Share on other sites More sharing options...
TMKM Posted March 22, 2017 Share #3  Posted March 22, 2017 Leica SF 40 is actually made by Nissin  http://www.nissindigital.com/i40.html  will work in Auto mode not ttl Link to post Share on other sites More sharing options...
Ingo Posted March 22, 2017 Share #4 Â Posted March 22, 2017 My SF 40 works fine in TTL. Link to post Share on other sites More sharing options...
Alo Ako Posted March 22, 2017 Share #5 Â Posted March 22, 2017 All Nikon mount flah units will work, they just won't offer TTL metering and output. Â Â You need a Nikon camera to set some variables on the SB 800. That`s the reason why I bought SF 64. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted March 22, 2017 Share #6  Posted March 22, 2017 All Nikon mount flah units will work, they just won't offer TTL metering and output.  The SF40 is clearly a rebrande Metz M400 and indeed, there is a version of this that at least purports to be compatible with Leica, meaning, I pressume, that it offers TTL metering and output:  https://www.parkcameras.com/p/9353654P/flashguns-panasonic-fit/metz/mecablitz-m400-flashgun-for-olympuspanasonicleica  The SF40 is made  by Nissin. It's a re-badged i40.  The flash you reference is designed to do TTL on the Panasonic/Leica cameras. ie: those following the 4/3 protocols (Olympus and Panasonic). Unfortunately the "real" Leicas don't use that so for  S, SL, M and T cameras you'll need a Leica branded flash for TTL.  Many other flashes work very well for auto or manual functionality though if you don't want/need TTL.  Gordon Link to post Share on other sites More sharing options...
geetee1972 Posted March 22, 2017 Share #7  Posted March 22, 2017 Advertisement (gone after registration)  The flash you reference is designed to do TTL on the Panasonic/Leica cameras. ie: those following the 4/3 protocols (Olympus and Panasonic). Unfortunately the "real" Leicas don't use that so for  S, SL, M and T cameras you'll need a Leica branded flash for TTL.  I did wonder about this and thought that might be the case.  You have to marvel at the bare faced cheek of Leica charging more than double for the same thing though. It is slightly reminiscent of Hasselblad rebadging Sony A6000s and asking $8k for them . Link to post Share on other sites More sharing options...
AlexP Posted March 22, 2017 Share #8 Â Posted March 22, 2017 so SF64 will give you TTL? Link to post Share on other sites More sharing options...
denisavu Posted March 23, 2017 Share #9 Â Posted March 23, 2017 Yes, the SF64 will give you full functionality. In a multi-light setup, any manual flash would work. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted March 23, 2017 Share #10 Â Posted March 23, 2017 so SF64 will give you TTL? Â When matched with the SL you get TTL, assisted auto (aperture and ISO sent from camera but exposure via a sensor on the flash), manual and wireless slave (manual). Â You can set FEC via the camera OR flash and they'll both know. Head zooms to 200mm. Â Apart from wireless TTL it's a great hotshoe flash. Â Gordon Link to post Share on other sites More sharing options...
Alo Ako Posted March 23, 2017 Share #11  Posted March 23, 2017 Its a damned lousy simple flash if you compare it with Canon, Nikon, Sony etc...Leica and flash, that`s a bug, not a feature Link to post Share on other sites More sharing options...
denisavu Posted March 23, 2017 Share #12 Â Posted March 23, 2017 They're still light years behind Canikon Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted March 23, 2017 Share #13 Â Posted March 23, 2017 I use Profoto B1 heads..............they work great with the Air Remote Link to post Share on other sites More sharing options...
Allen B Posted April 5, 2017 Share #14 Â Posted April 5, 2017 I'm not sure that the Air Remote will do TTL. Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted April 6, 2017 Share #15 Â Posted April 6, 2017 I'm not sure that the Air Remote will do TTL.i don't like TTL Link to post Share on other sites More sharing options...
