M10 Color - Update in Lr 6.8
Rick
Just re-process in the develop module.
Jeff
Thank you for the quick answer. I do not understand though.
If I understand correctly I changed the Adobe Standard profile that is by default being applied to the M10 files. Is it possible to restore the Adobe Standard profile without my changes (being saved into the profile?)?
When I import a M10 file it looks in Lightroom as the attached files illustrates. If I remember correctly, not all of the values are set to zero when using the Adobe Standard profile. Am I correct?
  • Replies 50
  • Created
  • Last Reply
Go into the calibration panel in the develop module and choose the profile you want. Changes are non-destructive and you can use the history log to revert to any point.
Jeff
Yes, I'm aware of that, Jeff. Can you please confirm if it is correct that the values shown in my screenshot are really zeroed out when using the Adobe Standard profile?
I think at import these numbers would be zeroed out regardless of profile chosen, before any subsequent changes.
Yes. The only parameters that wouldn't be, for raw capture, are white balance/tint in the Basic panel and the values in the Detail panel.
When you use Adobe Standard Profile the values are set to zero I think.
If you want to reset to the Adobe standard profile, as you set your default, go to Develop -> Set Default Settings ..., then you will see "Restore Adobe Default Settings"
I wonder if this is what you want. ^^
By the way—Adobe Lightroom 6.9/ CC 2015.9 is out ... and so are Camera Raw 9.9 and DNG Converter 9.9. From what I can tell, there's no difference to the previous version regarding the two integrated Leica M10 colour profiles ("Adobe Standard" and "LEICA M10").
That’s subjective. I’ve never liked the way Adobe normalizes cameras with its Adobe Standard profile. Or are you suggesting that the Embedded profile somehow looks better in 6.8 versus 5.x?
Let me rephrase...
5.x does not have a profile specifically for the M10, while 6.8 and on does.
