mmx_2 Posted January 26, 2017 Share #1 Â Posted January 26, 2017 Advertisement (gone after registration) Hi! Â I decided to create a 3D-printed version of the famous OUFRO inspired by ECHO63:s mockup made from a front and rear lid. Since I had both mounts already drawn up in 3D, it was a quite simple task to create the OUFRO. . It's also published on Thingiverse. Enjoy! Â https://www.thingiverse.com/thing:2064523 Â Â Â Â First picture taken with the "OUFRO": Link to post Share on other sites More sharing options...
Advertisement Posted January 26, 2017 Posted January 26, 2017 Hi mmx_2, Take a look here 3D-printed OUFRO. I'm sure you'll find what you were looking for!
helged Posted January 26, 2017 Share #2 Â Posted January 26, 2017 Great! Â Since the back cap of SL-lenses is such a pain to get hold on - any possibility for you/others to make some...? (has been requested on the SL pages several times). Link to post Share on other sites More sharing options...
mmx_2 Posted January 26, 2017 Author Share #3 Â Posted January 26, 2017 Great! Â Since the back cap of SL-lenses is such a pain to get hold on - any possibility for you/others to make some...? (has been requested on the SL pages several times). Sure it's technically possible, my problem is that I only own an S and a M, I'll talk to my dealer, maybe I can borrow a cap from them . It would be in a grey zone copyright wise though (the M-mount is completely free since many years, but not so sure with the SL...). I've made both front cap and back lid for M. Link to post Share on other sites More sharing options...
DMJ Posted January 26, 2017 Share #4 Â Posted January 26, 2017 Never having played with this, how robust is the plastic of the item you make? Link to post Share on other sites More sharing options...
Lord Lucan Posted January 27, 2017 Share #5 Â Posted January 27, 2017 I think it should be as good as plastic. Link to post Share on other sites More sharing options...
mmx_2 Posted January 27, 2017 Author Share #6 Â Posted January 27, 2017 Hi all! Â Â The material is called Zortrax Ultrat (it's a proprietary from my printer maker Zortrax), but basically it's a modified ABS-plastic that is very sturdy. Actually all caps and lid from all camera manufacturers are from ABS-plastic (although the mix might vary to give it different properties). My old printer used PLA instead (it's a plastic made from Corn) and although it had very good impact strength it was a quite brittle material so small chips would easy come of from it when used in mechanical parts. With Ultrat all those problems are gone. For a smoth surface I treat the plastic with acetone vapor. Â //Joakim Link to post Share on other sites More sharing options...
Maarten Posted January 27, 2017 Share #7 Â Posted January 27, 2017 Advertisement (gone after registration) Take care with the acetone for smoothing up plastic parts. Â Some plastics, notably polycarbonate, loses all mechanical properties after contact with acetone. Polycarbonate is under development for 3D printing and should give even better results than ABS. Blends of PC and ABS are very popular too and might see the market for 3D printing soon as well. The current Leica lens rear cap is made from PC/ABS. Link to post Share on other sites More sharing options...
mmx_2 Posted January 27, 2017 Author Share #8 Â Posted January 27, 2017 PCABS is also available for the Zortrax printers. I haven't tested it yet, but I think it should be a good material for mechanical parts. Link to post Share on other sites More sharing options...
