Leica q has paint chip missing - how to fix?
karla1
x
To me the main issue os not the paint chip, it's the mechanical behavior now the camera has been shocked.
I believe what you should check carefully is the autofocus system, the OIS (anti blurring) activation, and even the auto f-stop. Activate and deactivate them, listen the noises, see the effect on a real picture that you take.
I think nothing else "moves" in the cam, so unless a terrible shock misaligns the lenses (which would obviously show @100% size on the pics) you should be OK with these.
And if the seller doesn't want to let you test this way, given the cost of the cam : let him die.
Guest jvansmit
if the underlying metal is scratched then the warranty may be compromised.
My warranty was voided when I scratched the bottom of the camera along some concrete a year ago. The scratch was 2-3mm long which I didn't think was at all significant but Leica thought otherwise.
