how about M10Mono
esquire53
what would a ND do differently than a proper exposure compensation or exposure setting?
If the subject dynamic range is beyond that of the sensor, e.g. subject indoors at a window with a sunlit exterior, there is no single correct exposure that captures all the detail in the scene.
Extending the sensor design to improve dynamic range would help in this situation.
However with an increased dynamic range sensor, it is also important that the output bit depth of the analog to digital and de-mosaicing conversion is increased to maintain separation of details in low contrast scenes.
the comment was related to ND filter from the comment earlier and the ND will not help for highlight section, just makes it darker, so the exposure could do the same thing and with the lowest ISO of 100 you could expose faster with wider aperture
Rather than one ND filter for the whole lens or sensor, I think the original suggestion was for a per-sensel matrix of ND filters so the sensels had different sensitivities across the exposure range.
The effect would be to broaden the exposure range of the sensor as a whole, at the expense of resolution and ceiling ISO.
At the end of the day, though, one would still need to ensure that the final, interpolated, full exposure-range image did not itself have blown-out highlights.
How would that work?
Conceptually, I've considered a few possibilities.  Something akin to bracketing, but designed specifically with highlight preservation in mind.  Or visual indicators like zebra striping when using EVF/LV.  Bringing back the RAW histogram and zone indications from the original Monochrom would certainly be a step in the right direction, particularly if they were live.
The next Monochrom needs highlight protection. The fragility of highlights was by far the biggest drawback for me. Shooting in bright daylight or high contrast environments was like trying to delicately cook an egg on a 2000 degree surface.
If you change the light meeting from classic to advanced, it doesn't overexpose. But it is slower...
