Infinity focus and central patch with 24mm
FeralCoton
I got a new 24mm elmar for my mp240. It works wonderfully but I noticed that when I focus the lens to infinity, the central rangefinder patch does not seem completely in focus (as though I need to move the focus ring a bit more). I don't think it's the camera as the central patch is fine with my 35mm and 50mm. The shots with the 24mm at infinity are fine, but the central patch doesn't quite align.
Is this normal as I know the 24mm exceeds the rangefinder field of view?
Sent from my iPad using Tapatalk
The rangefinder patch is basically asking you to back focus. It's probably the lens that needs calibration but maybe the depth of field of the 24mm will be enough to cover for the issue. I would recommend to do a close focus test to judge the seriousness of the problem.
They always want both, as they must be calibrated to the common standard and Leica wants to make sure the whole system is spot-on.
i know , and it makes sense, but it takes too long !   i know i know the quality of the work is very high - i agree.
I feel abandoned without my M. I am fortunate to have my T to pass the time. I was a little puzzled why they wanted both and hope the focus isn't thrown out on other lenses that were fine. The very knowledgeable person at the LA store assured me.
  • 3 weeks later...
